How do I check the rear suspension? | FerrariChat
Discussion in '308/328' started by DWPC, May 9, 2012.
  1. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    I'm getting a distinct "clunk" in the rear suspension when I go over bumps. What can I do with a floor jack and handtools to locate the source?
  2. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    Hmmm.must be the bushings.....then it might also be be the CV joint. But you can inspect the bushings with the jack easily as you know. Not sure what you can do to check the CV other than a test drive and listen. Oh, check the engine mounts too by trying to jack the engine up a bit.
  3. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Don't know if this helps
    [ame]http://www.youtube.com/watch?v=ALpWCjXoUGY[/ame]
