How do I clean inside 360 headlights? | FerrariChat
Discussion in '360/430' started by Jeru, Nov 24, 2005.
  1. Jeru
    Jeru Karting
    Nov 16, 2003
    64
    Florida
    Shawn
    I have alot of watermarks inside the lights.
    How do I take them out, Apart, and clean inside?
    Thanks!
  2. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    They are sealed units. I do not believe you can seperate them.
  3. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,858
    San Jose, California
    I'd also like to know how to take them apart. If they are sealed, you wouldn't think they'd get so many waterspots inside. I'd also like to know how to replace the bulbs, and how to replace the lens, if ever cracked.
  4. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    IIRC they are sealed shut except for a small drain hole and cannot be taken apart...... if you do a search there have been a bunch of threads on the subject over the years. There was one guy that had a small leaf get inside and couldn't figure out hot to get it back out......
  5. lrattner
    lrattner Formula Junior
    Sep 15, 2004
    390
    Delray Beach, Fl
    Dr. Lonnie Rattner
    I had a similar problem with the sealed units in an M Coupe. BMW replaced the units under warranty because they are suppose to be sealed so nothing should be able to get into them.
  6. SrfCity
    SrfCity F1 World Champ
    Apparently you can pull the bulb out and there's a hole that you can access. Then, you'd have to fashion a cleaner on the end of a stick to get at the inside of the lense. Not worth it IMO. It seems like most 360's have it so just join the club.
  7. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    You can access the bulbs by jacking the front up and removing the wheels. There is an access cover under the wheel well. SrfCity is correct in that once you remove the bulbs there is a small hole. The trick is trying to figure out how to clean the whole lense through a small hole!
  8. SoftwareDrone
    Sponsor Owner
    Jan 19, 2004
    7,858
    Well I have this gynecologist friend...
  9. seinfeld
    seinfeld Formula Junior
    Jul 6, 2004
    748
    Diamond Bar/Cali
    Gary
    since there is a small hole...and there is a leaf inside...just get a high powered Vacuum and suck it out...well, that is if u haven't tried that yet. As for the water drops...the best thing to do is probably just get a stick and fashion up some sort of absorbant tissue to the end and dry the wet spots.
    Im sure there are better ways...but give it a try. :)
