How do I know if my headers are cracked? | FerrariChat
Discussion in '360/430' started by bshah, Jun 29, 2012.
  1. bshah
    bshah Formula Junior
    Jun 28, 2011
    326
    Chicago
    #1 bshah, Jun 29, 2012
    2006 430 Coupe F1 with updated headers.
    I have noticed some weird rattle noise (sound like a bunch of empty beer cans hitting each other in a bag) when I start my car, when I accelerate up to 2nd (F1) and I think when slowing down.
    Also, off the line, the car does not seem to engage as it used to.
    I had the headers replaced about 1000 miles ago already....is it possible they went bad again?
    Thanks.....
  2. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    If you are talking about a 430, it sounds like the problem is downstream from the headers. The leaks are actually difficult to hear at first at least and do not sound like a rattle.
    So far, I have not heard of any failures of the updated headers.
    Dave
  3. Moopz
    Moopz F1 Veteran
    5,553
    Orlando, FL
    Perhaps the exhaust brackets broke. They will continually break over time because of their fixed attachment.
    Off the line engagement sounds like a different issue, more clutch related.
  4. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    I had the exhaust tips on my F430 replaced twice. When they broke, they sounded like ball bearings in a coffee can. This may be what you're hearing on your car.
    When it's in for service, they can check your headers for cracks.
    When my F430 was in for it's last fluid service, they swapped out both headers as well.
    My car is an '07.
  5. Gh21631
    Gh21631 F1 Veteran
    9,143
    East
    If you have cracked headers you will hear a clicking sound. The worse the crack the louder the clicking. Sounds like your issue is exhaust brackets.
  6. fmaderi
    fmaderi Formula Junior
    May 8, 2005
    258
    clearwater Fla/NY
    frank maderi
    check the brackets first. look for a rust stain and look close for the crack or loose/broken clamp . dont think it is a cracked tip/pipe but look . youll need to remove the bumper. you might see it with a mirror . forza
  7. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    It could be many, many things rattling back there. Could be cat heat shields with a broken weld. Could be loose flange bolts. Could be loose bay covers. The undertray could be hanging off...get it to a tech who knows what to look for and avoid Internet conjecture...
  8. Afonsolaw
    Afonsolaw Formula 3
    Sep 11, 2011
    1,911
    New jersey
    I was told by the tech at ferrari that if you have a chrack in the headers you will definatly notice it... aparently it is much louder sound and it dosent sound good... but I agree with what everyone else has been saying that it is an exhaust bracket.
  9. bshah
    Jun 28, 2011
    326
    Chicago
    thanks for the reply. I will take a look tomorrow and let you know what I see....
  10. PbPedis
    PbPedis Formula Junior
    May 6, 2007
    710
    Ontario, Canada
    Dennis
    As above, more likely exhaust brackets as they are known to crack. I had a rattle at start up as well and my bracket was cracked, and some welds on my Tubi tips had cracked. The rattle was gone after both of those were replaced.
  11. m.roberts
    m.roberts Formula Junior
    Nov 2, 2009
    907
    I had a lot of rattling at idle, I also has almost zero power when accelerating from a stop.... Almost like it was in the Ferrari limp mode.
    I also kept getting CELs related to fuel problems and misfires... It was all due to the headers being cracked
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #12 2NA, Jul 1, 2012
    Eddie is right. There are way too many things making noises to identify a leak that way. The sure way to identify even a minor leak is by "smoke testing" the exhaust system. Bring the car to someone with the right equipment and you'll soon know the answer.
    This 355 had leaks at exhaust flanges, the headers were fine.
  13. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    I concur.
    The proper diagnosis will lead to the right repair.
  14. bshah
    Jun 28, 2011
    326
    Chicago
    I have not picked up my car yet, but it appears the problem has been solved.
    I was told the outer surround of the exhaust tips were rattling and all the tips have been replaced. This was done under my POWER warranty.
    Has anyone else had this problem?
  15. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I've seen it before.
