How do these compression readings look? (208 GT4) | FerrariChat
Discussion in '308/328' started by fastricky, Nov 10, 2021.
  1. fastricky
    fastricky Karting
    97
    rich buceta
  2. fastricky
    fastricky Karting
    97
    rich buceta
    This is for a car I'm considering buying... pls fill me in and thanks! - Rich
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    Give us the actual numbers - its hard to read the gauges - general rule of thumb is +/- 10 % for all -
  4. fastricky
    fastricky Karting
    97
    rich buceta
    OK yes I can see they are hard to read:
    C1: 155psi, 11kg/cm2
    C2: 150psi, 10.5kg/cm2
    C3: 155psi, 11kg/cm2
    C4: 135psi, 9.5kg/cm2
    C5: 140psi, 10kg/cm2
    C6: 140psi, 10kg/cm2
    C7: 145psi, 10.25kg/cm2
    C8: 140psi, 10kg/cm2
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Too much variation for me... I'd repeat the test, insuring that: the throttle is fully open, each cylinder gets the same number of "strokes"- 6 is a good number that will ensure a max reading. Also, the engine should be at operating temp when comp check is done because ring sealing when an engine is at normal temp is far more important than ring sealing when cold.
    Admittedly, cold compression checks are common but they are often not accurate when checking for normal variation. I have seen cases where the amount of variation in your example would essentially disappear when the engine is warm...or get worse. Cylinder walls do not necessarily expand uniformly. A cylinder that is round when hot may not be when cold and visas versa. What matter is how the engine seals when at normal operating temp.
    Albert-LP likes this.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Seems a little low to me but it depends on atmospheric conditions.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    How many miles on the car? Also mike996 is right, do it at normal operating temp if you can and have the throttle wide open (WOT)
  8. Albert-LP
    Albert-LP F1 Veteran
    8,175
    around Modena, Italy
    Alberto Mantovani
    It doesn't look bad, but it's very likely a never rebuilt engine. 208 GT4 are more or less all in this conditions.
    ciao
    Pero likes this.
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    When we "released" an engine after rebuild, the max allowable variation from high to low cylinders was 5PSI. Admittedly, these were performance/competition engines, not a rebuild of a "grocery-getter" motor. If I saw the readings per the original post, and they were rechecked/verified, I wouldn't like it but for practical purposes/normal driving the variation shown is not worth worrying excessively about.
    FWIW the compression check on my 328 when I purchased it in '08 showed 8PSI max difference between the high and low cylinder. That comp check was done as I recommended earlier - engine hot, 6 cycles on each cylinder, throttle body full open.
    Pero likes this.
  10. kcsun
    kcsun Rookie
    Jun 29, 2021
    20
    ken cheek
    Wouldn't a leak down test be more useful?
    kc
  11. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,333
    Dumpster Fire #31
    SMG
    Similar but different:p
    Start with a compression test to determine if there's an issue to be investigated, if so then a leak down can help point to where that problem is coming from.
    Jack-the-lad, Albert-LP and mike996 like this.
  12. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    What's the elevation (feet above sea level) where the compression test was performed? For sea level, those numbers are on the low end. For 5,000 feet ASL, eg Denver, they're OK.
    Gordon
  13. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Well...again, the variation is the important thing. As noted, the specific numbers will change based on several different factors but the variation percentage between cylinders will not. As I said earlier, the variation in the OP's test is outside my personal comfort zone but that's based on my past work on performance/competition engines and probably not totally relevant. As far as an engine for driving down the road/having any problem, it's fine.
  14. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    Agree. It looks like a normally worn engine. Keep looking for other clues of a problem. For example, what are the spark plugs saying?
    Pero likes this.
  15. Albert-LP
    8,175
    Alberto Mantovani
    I think that an head service would reduce much of this variations: in my opinion the problems are valves more than the liners. Maybe even a valve adjustment service could help. Pay attention that disassembly the 208 engine is not easy, as rods are wider than the bore: to remove the pistons you have to remove the cranckshaft.
    ciao
    Pero likes this.
  16. fastricky
    fastricky Karting
    97
    rich buceta
    Some great information thanks everyone. I've moved on from the car (it's in France) - had a repaint/color change I wasn't aware of initially plus a few other surprises that made me think I needed to move on. Cost to ship a car is now over $10k btw, eye watering!
    miketuason likes this.
  17. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    "Cost to ship a car is now over $10k btw, eye watering!"
    WOW! :eek:
  18. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    552
    Tempe
    Jon
    Generally, due to variations between tooling, you want to see less than 10% difference between all cylinders (with the same tool, at same engine temp, etc).
  19. fastricky
    fastricky Karting
    97
    rich buceta
    I found another 208 GT4 I'm interested in, however the compression varies outside of 10% (readings are between 8-10 bar). Out of curiousity, is it possible to rebuild a 2l motor easily? Are the parts for such small pistons available? What is the cost of a rebuild?
  20. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    The 2 litre motor will cost at least as much as the 3 litre version, perhaps more - since they were produced in smaller numbers, the costs of specific unique items could well be higher - for example, the 2 litre engine had the same 71mm stroke as the 3 litre, but the 2 litre bore is 66.8mm, versus the 3 litre bore of 81mm. That means pistons, rings, cylinder liners are different and possibly more expensive for the 2 litre version (and you'll need at least a set of rings for a rebuild). Bearings are likely the same, but as smg2 has noted several times recently in different threads, finding rebuild parts is getting difficult and expensive lately. Some estimates say the cost of a proper rebuild (all bearings, rings, seals, valve work, etc etc) will be $15K USD or more - and the smaller displacement motor would possibly have a higher price tag. It would all depend on your engine builder, their experience, and parts availability.
    Gordon
  21. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    If you want 308 capacity I could sell you a set of used 81mm pistons, new rings and honed sleeves but suspect many on here in the US have them lying around. Not sure if any block mods are needed, I'm assuming 308 sleeves fit. The 208 heads are preferred by people wanting the most out of a 2V (more porting options) so you might find someone who will swap you your heads for refurbished 308 heads :)
  22. fastricky
    fastricky Karting
    97
    rich buceta
    Thanks gents, I've asked for a driving video, perhaps I'll post it up here when I get it. Gordon are all the parts for a 2L rebuild available?
  23. MITengineer
    MITengineer Formula Junior
    Feb 18, 2004
    374
    Montana
    I just had 2 cars shipped from EU (one was a friends 308 btw). You're getting hosed on shipping charges, I just paid 4800 EUR for a 20ft container. The 308 was RoRo and 1200 GBP.
  24. fastricky
    fastricky Karting
    97
    rich buceta
    Not sure how recently you had your most recent car shipped but rates have dramatically increased recently. Who did you use, I'll reach out to them.
  25. fastricky
    fastricky Karting
    97
    rich buceta
    FYI see attached the recent car's readings. How do you feel about this? My guess is the car probably still runs OK but is tired compared to a fresh built engine... thoughts?
