How do you adjust headlight travel on my GT4? | FerrariChat
Discussion in '308/328' started by oelboxer, Aug 19, 2022.
  1. oelboxer
    oelboxer Karting
    117
    Matt Wright
    1975 308 GT4
    I've read all of the threads on adjustment, and still can't get a definitive (or working) answer. One of my headlights parks higher than the other when down. Should be a simple adjustment right?
    Things I've done:
    - Detached the pivot arm and changed its position. When I do this, the light will go down further, but the motor pulls it back up so it parks in the same position. In other words, it dips down briefly then is back to where I don't want it.
    - Adjusted both the upper and lower stop screws. I have moved these completely out of the way and the light will still park in the same place. It stops long before it reaches the stop screw.
    - Made tiny adjustments via the manual headlight dials on the motors hoping it might make a difference - it did not.
    - Unbolted the entire headlight assembly mount to check to see if it was installed too high or too far back, which might make the headlight cover stand proud - no luck.
    I'm at a loss. Anybody have any experience with this? I must be doing something wrong. Thanks - Matt
  2. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    Is it just the front leading edge that is too high or all around?
  3. oelboxer
    oelboxer Karting
    117
    Matt Wright
    It's just the leading edge. Sits too high by about 1 cm at the front.
  4. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    I had this same issue but struggling to remember how I fixed it. I think I disconnected 22 from the splined shaft of the motor and adjusted the down stop so the headlight cover was flush. Then reconnected 22 to the shaft with the headlight down and tightened the nut 14.
