How do you determine accessory belt tension? | Page 2 | FerrariChat
Discussion in '360/430' started by RedNeck, Apr 2, 2017.
  1. Motob
    Motob Formula 3
    Nov 11, 2003
    2,343
    Frederick, Maryland
    Brian Brown
    Doing an accessory belt change is pretty straight forward. The hardest part is removing the rear under tray and the trim and access cover behind the seats. Use a the frequencies from the CS manual, the frequencies on the regular 360 manual are incorrect and have been updated by Ferrari to the CS specs.
    I know this for sure, because the first belt change I did, I set the belt tensions to the specs in the paper 360 shop manual and the P/S belt squealed like a pig. It was no fun taking the car apart for free to reset the belt tensions.
    The reason that the P/S belt frequency is so high, is because it has such a short run. Think of the belt like a guitar string. Compare two belts: One belt with a very long run at the same tension as a belt with a very short run. Like moving up the frets on the same string at the same tension on your guitar. The long belt will have a much lower frequency than the short belt even though the tension is the same in both belts.
  2. kaj750
    kaj750 Formula Junior
    May 9, 2022
    262
    Fresno, CA
    Yes. Checking the frequency is pointless, as the hydraulic tensioner sets tension, no matter what you measure.
    I set my tension until the pins slide in and out easily. I then turn the engine over 1-3 times and recheck.
    Be sure you allow ample time in between adjustments, as the tensioner takes time to adjust. Like a full minute, or so.
  3. RedNeck
    RedNeck F1 World Champ
    11,996
    The CSA
    Me
    Wow. This was from 8 years ago when my car was "new" to me. I've done it several times since then. :D
