how do you drive your FF | Page 2 | FerrariChat
Discussion in 'FF/Lusso' started by Mn-0127, Feb 18, 2015.
  1. Eric360
    Eric360 Formula 3
    1,425
    San Francisco, CA
    Eric
    I had the same problem. You just need to get one of these.... https://www.fillernecksupply.com/1963-1976-mopar-b-body-fuel-tank-grommet-filler-neck-seal/
    Or search my thread about gas pump problems. The gas pump nozzle doesn't quite reach far enough into the FF filler, thus not triggering the flow switch of the gas pump nozzle. You can trigger it with your hand or get this simple device. It solved my problem instantly.
  2. baguns
    baguns Karting
    Sep 19, 2012
    246
    Yorba Linda, CA
    Thanks. Just ordered it. Does the grommet just sit on top of the opening for the gas (not sure what it’s called)?
  3. Eric360
    Eric360 Formula 3
    1,425
    San Francisco, CA
    Eric
    Yes, the grommet just sits on top of your gas filler opening between the nozzle. It just allows the nozzle to go further deeper and engages the nozzle switch (which you don't see). I had this problem and I drove around to different stations trying to fill it. I was like WTF is with this car??? With this gas guzzler, I was worried I couldn't even make it to the dealer if I couldn't put gas in it! This will solve your problem.
  4. baguns
    baguns Karting
    Sep 19, 2012
    246
    Yorba Linda, CA
    Does the grommet need to be glued or fixed to the opening? Or simply friction holds it in place.
    Really need a heads up on this when getting an FF.
    On a separate but related note, I have issues filling the tank on my 430 scuderia, similar to what I notice with FF but not as bad. With the scud, I push the gas nozzle in and can only pump for a second and then it stops. I can only press the lever slightly and it will sloooowly fill up. Takes forever, but at least I can get gas in whereas FF gas wouldn’t even come out.
    Wonder if it’s the same thing in the scud and the grommet will also fix that issue.
  5. Eric360
    Eric360 Formula 3
    1,425
    San Francisco, CA
    Eric
    I think it's probably a similar issue with all Ferraris as I think they use the same parts/filler neck for many of their cars. You just put the grommet on when you fill it. Just keep it in your car/glove box and only use it when you fill up. Buy another one for your Scud. Problem should be solved.
  6. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    I need to look at the gas pump closely next time to see where that sensor is.
  7. Sonicsound
    Sonicsound Karting
    May 14, 2017
    125
    Boomhauer and otakki like this.
  8. Sonicsound
    Sonicsound Karting
    May 14, 2017
    125
    Correction “Always in Manual”
  9. papou
    papou Formula 3
    1,577
    plantation Fla
    daniel ross
    otakki and Sonicsound like this.
  10. Sonicsound
    Sonicsound Karting
    May 14, 2017
    125
    papou - Love it! New & Old School
  11. My 1st
    My 1st Karting
    174
    Gladwyne, PA
    Scott
    Papou, get an old milk crate. That’ll reduce the likelihood of the propane tank rolling around.
  12. Sonicsound
    Sonicsound Karting
    May 14, 2017
    125
    The key to that recommendation is an “old” milk crate.
  13. papou
    papou Formula 3
    1,577
    plantation Fla
    daniel ross
    Guys it’s 2019 milk crate ! CBD baskets. But yes good advice..
    Sonicsound likes this.
  14. timjen88
    timjen88 Karting
    Aug 20, 2015
    241
    Colorado/Palm Springs
    only annoying thing I have experienced is the loudest beeping of any car I have ever been in, wish there was a button for that!
    Sonicsound and Eric360 like this.
  15. ttforcefed
    ttforcefed F1 World Champ
    18,877
    it the car settings there seems to be an option for increasing and decreasing the sounding setting - i cant get it to work - have you tried that? scroll the settings on the left hand side of the car
  16. ttforcefed
    18,877
    im in auto 90 percent of the time in the FF. it does everything better than i can.
    otakki, Boomhauer and crinoid like this.
  17. papou
    papou Formula 3
    1,577
    plantation Fla
    daniel ross
    +1 absolutely wonderful machines..
    otakki and Boomhauer like this.
