How do you fix these minor issues? | FerrariChat
Discussion in '308/328' started by BassMan, Sep 9, 2009.
  1. BassMan
    BassMan Formula Junior
    Aug 14, 2008
    626
    Long Island, NY
    Andy
    1. The cigarette lighter socket on my 328 does not work ( checked with voltage meter). Also checked fuse (OK).
    How can I remove the whole socket to fix / replace?
    2. Also, the light for the left fan on the instrument panel has come loose and is dangling. How can I reattach?
    3. My foglight switch will turn on if depressed but then turns off. Do I have to replace the switch or can I fix by making an adjustment?
    Just a couple of minor projects to keep me occupied :)
  2. BassMan
    Aug 14, 2008
    626
    Long Island, NY
    Andy
    Nonody knows how to remove a cigarette lighter?
  3. speedy
    speedy Formula Junior
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    I have never removed my cig lighter but I would suppose you would have to access it from the underside of the panel. It may be a simple pop in but I wouldn't pry on it unless i knew exactly how it's put in there.
  4. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Lighter comes out from the bottom. Remove center plate and it will uncsrew from the bottom. Do we assume that the fuse is OK.
  5. BigTex
    79,386
    Houston, Texas
    Bubba
    What you are calling fog lights are actually Passing Lights it's a momentary switch for flashing people..
    Wrap some two sided tape around the broken dash light holder until it jams back in and stays...or you can buy a new ring that still has the detent snaps..
    You have to pull the console to reach most of the items mounted on it..
  6. BigTex
    79,386
    Houston, Texas
    Bubba
    No ....yours may be driving lights looking at your car, bad switch??
  7. fdekeu
    fdekeu Formula Junior
    631
    Belzium
    Frank
    The fog lights were optional on the 328 & Mondial 3200
    On my friends 328 they are daylight passing lights
    On my Mondial I have the fog light option
    They are switched on/off on the console and the passing function does not work anymore
    If you can switch them on it means the switch is working
    Pressing the switch again should turn them off
    Check the relay
  8. BassMan
    Aug 14, 2008
    626
    Long Island, NY
    Andy
    Fuse is fine. Thanks for the tip on pulling the center plate - will try.
