How do you guys store your ferraris? | FerrariChat
Discussion in 'United Kingdom' started by noony, Mar 21, 2004.
  1. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    Our garage isn't wide enough for a 355/360/512tr. Is there anywhere else we could store the car during the week? I have to come up with a solution or my dad will just get another porsche...
  3. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    The obvious answer is a lock up garage near to where you live. I would'nt feel comfortable if it was too far away and insurance might be an issue.
  4. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    Insurance couldn't be worse than if it was just left outside though?
  5. Davey S1
    Davey S1 Formula Junior
    Jan 20, 2004
    375
    Cardiff, Wales
    David
    Outdoor Carcoon?
  6. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    That's an idea....would it help insurance at all?
  8. smiffy
    smiffy Karting
    Feb 7, 2004
    224
    cardiff
    I'll look after it for you! LOL
  9. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    Cardiff is too far away ;)
  10. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    I've got a feeling you need to alarm a garage if it's not part of the house where you store your car. Don't even think about buying a F car and parking it on the street.....
  11. Davey S1
    Jan 20, 2004
    375
    Cardiff, Wales
    David
    Take out the living room windows and put in an up and over door. You could sit in it while watching tv.
  13. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    It wouldn't be out on the street. We live in a cul-de-sac-type-thingy and we are third house in off the road(very quiet area) Donty know if that would help...
  14. felix66
    felix66 Karting
    Feb 21, 2004
    175
    London
    Might sound like a daft question but I traded up to a 355 from a Boxster and worried about the car fitting but the size isn't much different (355 is larger but not a great deal) - if your garage takes a porsche it should take a 355 - not sure about dimensions for the 360.
  15. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    Yes. When the 996 C4(narrowbody) goes in with the wingmirrors out there is about an inch to spare. Getting in is the only problem, sorry, I should have made this clear.Maybe we could get a new doorframe which gives an extra few inches? A 360 is just less than an inch wider than a 355.
  16. felix66
    felix66 Karting
    Feb 21, 2004
    175
    London
    Yep - thats a narrow door!
    You might try a roller door - they have a frame thats about half an inch wide each side! They normally are electric which is always nice to have!
  17. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    Thanks, I'll look into it. I'll measure the width properly tomorrow too. The wingmirrors on a 355 fold in right?
  18. felix66
    felix66 Karting
    Feb 21, 2004
    175
    London
    yes they do.
    I thought my garage door was narrow at 80 inches (the 355 with mirrors out is around 76 inches - I think).
  19. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    our 996 is 69 inches wide and you can see how little space there is :( But we will see. If not...we can always buy the nexdoor neighbours double garage ;)
  20. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    If this helps , 355 dimensions are;
    length-167.3 inches
    width- 74.8
    height-46.1
  21. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    Cheers-I'll measure it up tomorrow and post the results.
  22. ric355
    ric355 Guest
    Dec 21, 2003
    1,375
    The wing mirrors do fold in on a 355, but you have to be careful. The rear of the car is a lot wider than the front, but the wing mirrors are the widest part. So if the mirrors are in the normal position and they go through a gap, then you know the whole car will go through.
    However, if you sequeeze the car through a gap with the mirrors pulled in, then it is possible that the back end won't go through, so you have to use your mirrors to look at the rear arches to check clearance. Hang on a minute though, you just pulled them in to get it through a gap....
    So best policy with a 355 is mirrors out all the time. This is probably the same for other models too.
    Richard.
  23. noony
    noony F1 Veteran
    Nov 25, 2003
    5,903
    Seoul
    Johnathan
    Thanks Ric. Our garage door is 83 inches wide, so maybe we can get a ferrari after all :)
  24. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Let me know where you live and i'll try and get over so you can see for sure.
  25. ric355
    ric355 Guest
    Dec 21, 2003
    1,375
    #22 ric355, Mar 22, 2004
    To give you some idea of clearance, here are some pics of my car as it enters the garage door, plus one showing the door opening. I have the same width door - 83".
    In the pics, the left side mirror is slightly in front of the door frame and the perspective in the picture is making the gap between mirror and frame look slightly narrower than it actually is. The right hand mirror is lined up exactly with the door frame.
  26. daz355
    daz355 Formula Junior
    Jan 31, 2004
    743
    MclarenVille
    Darren P
    I'm glad that I'm not the only one who has this problem.Losing abit of weight helps getting in/out of the car.
    Daz
  27. Badapple
    Badapple Formula Junior
    Nov 20, 2003
    875
    West London
    Phil
    #24 Badapple, Mar 22, 2004
  28. BigTex
    78,465
    Houston, Texas
    Bubba
    Outside, in the rain. Under a tarp.
