How do you position the tensioner arm for a 355 timing belt? | FerrariChat
Discussion in '348/355' started by carwhisperer, Dec 21, 2015.
  1. carwhisperer
    carwhisperer Formula Junior
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    What is the proper unloaded position for the arm that holds the tensioner roller on a 355? I would assume you set the arm as far down as possible, then tighten it's bolt (the one that goes through the rubber bushing). Then after that use the two holes in the tensioner roller assembly to adjust the gap?
  2. Rifledriver
    37,274
    #2 Rifledriver, Dec 21, 2015
    Is the tensioner arm not free to move without loosening the bolt?
  3. Robbe
    Robbe Formula Junior
    622
    The Netherlands
    You say unloaded position.
    Do you have a pin stuck in the hole to prevent the gap starting at more than 2.5 mm?
    If not , first compress it(carefully in a vice or so), put a pin in to lock the spring, and then bolt it to the engine.
    Then you can adjust the bearing to open up the gap to 2.5 mm.
    Of course with the belt on!
    Once the gap is over 2.5 MM, it is hard to get it back to 2.5 by turning the tensioner bearing. Better to start over again in that case.
  4. carwhisperer
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    Is that how it is supposed to work? Does the are just pivot on that bolt? I thought it had a rubber bushing that sort of positions it.
  5. Rifledriver
    37,274
    Yes.
    Yes.
    No.
    Sorry to say but maybe this isn't a good job for you.
  6. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    It does not pivot on the bolt. It pivots on a collar and the arm has a bushing that rotates about the collar.
  7. carwhisperer
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    It's OK. You're probably right.
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,031
    Indio Ca/ Alberta
    Grant
    Brian as rifledriver has stated in few words i might expand. This is a very important to say the least process.
    Kind of like timing the cams. Not to take you off it as it is your car but you do not want to make a mistake.
    Either have someone like rifledriver check your work or better yet have them do it so you can start building a relationship with a great mechanic. We all need them whether we will admit it or not.
    Good luck!!!
  9. carwhisperer
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    Thank you for the replies and the help. I got a few hours to work on it yesterday and I now believe that I understand how the system works, but I do have a couple more questions before I button things up.
    I used the needle nose pliers in holes 3 and 4 to rotate the roller bases to set the gap. I believe the manual says 2.5mm of gap while others have stated to set it where a pin slides in and out. On my car there is a pretty significant difference between the gap you get with those two methods. I used a 0.103" drill bit, which is about 2.6mm. When I use the pin, I get closer to 0.080. Now I believe the manual says "~2.5mm", so maybe I shouldn't be too concerned about that difference.
    A more troubling issue, however, is that once I start to rotate the engine, the gap changes. Furthermore, if I rotate it backwards, this slackens the belts.
    For a while I was concerned that one of my tensioners was dead because the gap was changing, but I don't think so. A couple times I took the passenger side one out and put it in the vice to compress it and it doesn't seem dead at all. I did make sure to close the vice jaws very slowly (1/2 of a turn per minute) as I read that doing it too quickly can ruin the dampener.
  10. carwhisperer
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    This helped a lot!
  11. carwhisperer
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    And this helped the most!
