How do you prevent braid-covered hose from unravelingy | FerrariChat
Discussion in '308/328' started by DWPC, Feb 6, 2012.
  1. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    A couple of the braid-covered non-fuel hoses on my QV's engine are looking pretty ratty because the braid unraveled at the original cut leaving a fuzzy collar near the hose end. Is there a way to prevent the cover unraveling on new hose or a new cut where I can cut it back to clean braid? Lacking other ideas I thought maybe a small collar of heat shrink tube would do it.
  2. ClydeM
    ClydeM F1 World Champ
    11,935
    Wayne, NJ
    Clyde E. McMurdy
    I've used fingernail clippers to nip the frayed ends, india black ink (non water soluble) to redarken the greying threads, and dabs of superglue to keep the ends from fraying. You'll find similar glue for similar issues in most fabric shops.
  3. John M
    John M Formula Junior
    Nov 18, 2004
    887
    Kentucky
    Haven't tried it on these hoses, but the usual way to take care of this would be to briefly pass the freshly cut ends through open flame (i.e. a pocket lighter).
    Best Regards,
    John M
  4. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    I think the braid on the hoses is cloth and trying to seal the end with a lighter won't work. Works fine for polymer braids but not cloth. You can always using a single wrap of electrical tape or some heat shrink tubing to tidy up the end.
  5. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,640
    Toronto / SoCal
    Rob C.
    The superglue trick works well and so does some clear nail polish or black paint. Just about any hardening liquid that can be absorbed into the ends to bond them together.
  6. bill brooks
    bill brooks F1 Veteran
    6,050
    waynesburg,pa
    bill brooks
    fray check or clear polyurethane.
    however, if they are frayed that bad, you probably need new hoses.
  7. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    Probaby just replace them...
  8. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    I am replacing them. I want to prevent the braid cover from coming apart at the cuts again.
