How do you remove the upper steering column piece? | FerrariChat
Discussion in '348/355' started by speedy_sam, Oct 17, 2008.
  1. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    #1 speedy_sam, Oct 17, 2008
    I am referring to the upper trim piece - see item #33 in the attached diagram. I have removed the lower trim piece and the screws connecting the upper and lower pieces. The upper piece is loose but cannot come out. Do you need to remove the steering wheel?
  2. plugzit
    plugzit F1 Veteran
    7,799
    Redondo Beach, CA
    Bruce Bogart
    You have to squeeze one to separate them after you remove the screw(s) that hold them together and separately the screws that hold the assembly to the column.
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    It seems to me that it's a tight fit, but no "trick" involved. You do have the steering column tilted all the way down, don't you? Or maybe you have to undo the instrument cluster (2 screws). I don't remember for sure, sorry!
  4. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    The bottom piece came out with no issues.
    I tried with the steering column in both up and down positions - the upper piece is moving around (i.e. it isn't attached) but doesn't want to come out. Maybe removing the cluster or wheel will provide some additional room.
  5. TheOnlyest
    TheOnlyest Formula 3
    Sep 25, 2007
    1,686
    Las Vegas Nevada, US
    Steve
    You need to tilt up the gauge cluster, remove the 2 phillips screws and just tilt it up, the top cover will come right out.
  6. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    That's right----2 guage cluster screws must be removed--then tilt the entire cluter up out of your way
  7. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    Thanks guys!!
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #8 ernie, Oct 17, 2008
    No no no no no.
    To get the top part off you LOWER the column. Pull the lever (#24) that is on the bottom down, then lower the column all the way down. NOW you will be able to lift off the top part of the column cover.
  9. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    I tried that. It didn't work.
    Steve's recommendation worked perfect. Lifting the instrument binnacle frees up the necessary space to take the piece out.
  10. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    Well it has always worked for me.
    None the less, I'm glad to hear Steve's solution worked better. If there is a better way to skin the cat I'm all for it.
