News
how do you replace air vents?
Discussion in '360/430' started by weebz69, Oct 28, 2014.
  1. weebz69
    weebz69 Karting
    Jul 11, 2014
    85
    Gilbert AZ
    Jason W.
    Hey guys I want to install F430 air vents into my 360. My question is do they just pop out with a screw driver or is there some secret to removing the old ones?
  3. netman
    netman Formula 3
    1,883
    OC SoCal
  4. hakankuy
    hakankuy Karting
    Jun 15, 2010
    127
    Earth
    #4 hakankuy, Oct 29, 2014
    It is an easy DIY job. But you have to be careful whle installing new ones. Alignment is important. You will need a small screw driver probably where you have to use it gently while removing the old ones. If the new ones are not enough tight-fitting you may use tiny amount of black silicone or etc. to fix it.
    I tried 430 ones but it did not match the general looking of dashboard (it looks so modern according to 360 dashboard) imo, then I went for 550/575 vents and those made me happy. Sorry for the poor quality of the picture.
  5. Performify
    Performify Karting
    145
    KCMO
    Eric
    I recently replaced the vents in my 360 with the 430 (as well as the 430 AC control unit upgrade) and wanted to share a quick tip and resources i found.
    This post and responses to it in the Pic of your 360 or 430 you took today or recently thread led me down the "small hook" approach.
    somehow I also got to this video which was an excellent resource:
    the tip -- a cheap source of the small hook that fits perfectly is this -- ladder hanger from Home Depot
    https://www.homedepot.com/p/Everbilt-10-3-4-in-Vinyl-Coated-Screw-In-Heavy-Duty-Steel-Screw-In-Ladder-Hanger-50-lbs-18012/202305456
    I actually had them on hand and thought of giving a try and it worked perfectly. I had a pair but only used one -- a little tricky to thread through the vent and a quick tug and the vent popped out no problem. they're coated in vinyl so you don't have to worry about them tearing up your finish, and they're only $3 if you're already at HomeDepot.
    Just for consolodation of resources, here are other Fchat threads I used:
    https://www.ferrarichat.com/forum/threads/installing-430-air-vent-on-a-360-can-it-be-done.569468/
    https://www.ferrarichat.com/forum/threads/a-c-vents-refinished.303610/
    https://www.ferrarichat.com/forum/threads/vent-removal-on-my-360.225942/
    Vents I purchased used from Eurospares (they were by FAR the most cost effective), part number is 68811300 if you'd like to try elsewhere
    https://www.eurospares.co.uk/search?partNumber=68811300
    and finally, pics for posterity:
    IMG_0283 by performify, on Flickr
    IMG_0284 by performify, on Flickr
    yes, the temperature display is in Celcius... it was half the price and I'm fine with it :)
    brookliner7 likes this.
  6. To remove this ad click here.
  7. LP360
    LP360 Karting
    153
    Lee
    brookliner7 and Performify like this.
  8. raywong
    raywong Formula Junior
    Aug 29, 2004
    661
    Hong Kong
    Raymond
