How does the Mondial Valeo gearbox work? | FerrariChat
Discussion in 'Mondial' started by Nuvolari, Jan 10, 2005.
  1. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    I spent a while in the archives trying to find an answer but none was forthcoming. I was wondering if anyone can offer more information as to how the Valeo clutchless gearbox worked on the Mondials. Specifically:
    1. Are the gearboxes the same between the cars?
    2. Specifically how does the clutch work? Is it dry plate?
    3. Is there a clutch pedal?
    4. What is the procedure for changing gears or pulling away?
    5. I know they made few but does anyone here actually own one or has driven one?
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    #2 Ferrari_tech, Jan 10, 2005
    The gearboxes (casings) were different, although the gear ratios (I think were the same)
    It has a fairly complicated system that operates the clutch, so without getting too technical there is no clutch pedal, when you select a gear the sensors detect that the clucth needs to be disengaged and the actuator mounted on the gearbox disengages and engages the clutch.
    They were a strange car to drive and it took quite a bit of getting use to - here in the UK we didn't sell that many and in fact the last few we had were converted back to normal gearchange.
  3. Steve Magnusson
    26,806
  4. AR!
    AR! Formula Junior
    Apr 8, 2004
    981
    Berlin, Germany
    Hm, it took me maybe 5 minutes :)
    As the footwell in the Mondial t is quite narrow not having to operate a clutch pedal is a plus.
  5. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    As a Valeo owner maybe you can tell us a little more about driving these cars. Namely how do you pull away from a stop or equalize engine revs during a downshift? There is a lot of 'feel' in using a clutch at low speeds so how does the system prevent really jerky movements?
  6. AR!
    AR! Formula Junior
    Apr 8, 2004
    981
    Berlin, Germany
    The gearbox is equipped with standard synchros. However, you can apply a little throttle during a downshift just like with the manual clutch.
    Operation at slow speed is very smooth and predictable.
