How embarrassing....348 horn has mind of its own | FerrariChat
Discussion in 'Technical Q&A' started by pjwardau, Feb 28, 2010.
  1. pjwardau
    pjwardau Karting
    Jul 31, 2009
    103
    Sydney, Australia
    Peter
    Took my 348 for a drive today...freeway traffic was good, but eventually banked up going home with the weekend drivers returning to town.
    Pulling up with the Hoi Poli ...my air horns started to sound. All by themselves!
    Pushed the horn button..it stopped. Caught a lot of death stares "like who does this jerk think he is?" The cycle repeated...eventually the horn just would not stop. Crap.
    Pulled over, popped the bonnet, pulled the horn relay. Silence! Slinked off into the traffic...and re-installed the relay at home.
    Bugger. All normal again.
    To be sure, I ordered a new pair of relays from Ricambi....but would be interested to hear from any guru on this embarrassing failure.
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    From my experience Pete, its just sticking relays. :D:D
    But see how you go after you fit the new ones. :D:D
  3. T - MAN
    T - MAN Rookie
    Feb 26, 2010
    33
    NC
    If the problem continues you may be in for a new horn pad switch. On some vehicles this comes with the airbag.
    I'll see what I can find for info.
  4. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Nice one T-MAN. But dont stress mate, the 348 never came with an airbag. ;);)
    If anything, the horn button may be on its way out. But I doubt it. :D:D
    Also, the relay's are much cheaper than the horn button so I would replace both relay's first and go from there. :D:D
  5. T - MAN
    T - MAN Rookie
    Feb 26, 2010
    33
    NC
  6. T - MAN
    T - MAN Rookie
    Feb 26, 2010
    33
    NC
    I concur.
    Most times I'll swap them with another component say, the fog lights or defroster as a test.
  7. pjwardau
    pjwardau Karting
    Jul 31, 2009
    103
    Sydney, Australia
    Peter
    Thanks for the feedback guys....will pick up the relay(s) next week, (why order one when you can order two) :)......hopefully that is the source of the problem.
    P.S.
    Despite the air-horn having a mind of its own..really enjoyed the day out...doesn't an F-car sound soooo cool going through 6000+ rpm :)
  8. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Why fix the wimpy Italia-tooter?
    I've got a Motorola HD Emergency Vehicle Siren module for sale. And how often do you use "Hi-Lo, Whelp, and Wail in normal conversation.
    What does one do after pulling over a cop with a Ferrari? Probably best to cover plates before pressing 'ON'.
  9. T - MAN
    T - MAN Rookie
    Feb 26, 2010
    33
    NC
    I concur.
  10. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    sounds about right
    or thats wat happens when ferrari's reach pubity
    they do have a mind of their own sometimes
  11. T - MAN
    T - MAN Rookie
    Feb 26, 2010
    33
    NC
    I apologize for the double post. Posting from a smart phone isn't without it's perils.
  12. ClydeM
    ClydeM F1 World Champ
    11,903
    Wayne, NJ
    Clyde E. McMurdy
    I could see the horn going off & sticking if you had pressed the horn. But what would cause the relay to stick in the on position in first place?
    I'd think it's a short. Probably in the column.
  13. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #13 Miltonian, Feb 28, 2010
    Peter;
    Are you aware that the 348 steering wheel has horn contacts in the spokes, as well as on the center button? I had my 348 for five years before I discovered that! Duh.
    I wouldn't be surprised if your problem is that the contacts in the spokes are pushed together and completing the circuit to activate the horn, even if the center button isn't being pushed.
    I did an extensive thread a couple of years ago about diagnosing an issue with the horn on another members 348. I'm sure it's in the archives. I'll look. Edit: Here it is.
    http://www.ferrarichat.com/forum/showthread.php?t=56370&highlight=horn+brent
  14. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    The horn presents a considerable inductive load. As such a great amount of sparking at the contacts which commonly causes them to weld together. The other failure mode is pitting causing no contact.
    You have witnessed the effect on distributor points, which require a condenser (capacitor) to nullify the coil's inductive load. Only brute force of the rotor keeps them from welding shut.
    You will often find relays with supression circuitry on the coils to prevent contact pitting or welding on an expensive switch which energizes them as coils themselves are an inductive load. Reducing inductive sparking from motor loads such as the horn compressor is generally ignored as the cost isn't worth the price of an inexpensive relay.
  15. pjwardau
    pjwardau Karting
    Jul 31, 2009
    103
    Sydney, Australia
    Peter
    Yes...and that's why I am not convinced it is the relay....the RHS spoke swich is somewhat sensitive. That said....I can't find a part number for the switch, making me think *if* that is the problem might need a new steering wheel (!!) ..or might simply dis-connect that switch.
