How exactly is this heat exchanger an upgrade? | FerrariChat
Discussion in '360/430' started by collegeboy, Sep 30, 2025 at 2:17 PM.
  1. collegeboy
    collegeboy Formula 3
    1,420
    Texas and Kaua’i
    Mikey
  2. one4torque
    one4torque F1 Veteran
    5,788
    Houston
    One4torque
    “70 cooling tubes vs 55”.. I presume increased contact area for heat exchange.
    I don’t know that this is better or worse.
    collegeboy likes this.
  3. collegeboy
    1,420
    Texas and Kaua’i
    Mikey
    My thoughts as well. I feel like cooling isn't the problem. Failing and breaking mixing coolant with oil is the problem.
    Skippr1999 likes this.
  4. RedNeck
    RedNeck F1 World Champ
    12,531
    The CSA
    Me
    That is OEM, Ferrari changed the design a few years back. I've heard mixed reviews
  5. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,132
    Josh @jtcarprojects
    Try it and repot back
  6. Lola360
    Lola360 Karting
    Oct 26, 2023
    148
    Bay Area, CA
    Connor
    Is the original one not "full copper construction"? AW might know more about what makes it an upgrade.
  7. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,705
    Honolulu
    Kevin
    I am surprised that a more simple-to-make one isn't a thing. How about one with 5 larger tubes in it?...or three? Flow restrict, if needed, with some inserts?
  8. imahorse
    imahorse F1 Rookie
    4,505
    WI
    Dustin
    Fewer tubes would mean less surface area and less heat transfer.
  9. Kevin Rev'n
    Nov 29, 2009
    24,705
    Honolulu
    Kevin
    The tradeoff in minutes to achieve full temps would be?
  10. 066/8
    066/8 Formula Junior
    Sep 29, 2023
    283
    If you go from 55 to 5 pipes with equal total cross section area, it will take approximately 3.3 times as long (using conservative assumptions).
  11. collegeboy
    1,420
    Texas and Kaua’i
    Mikey
    Good point. I will contact AW Italia. Thanks.
