how fast can my 3.4L 308 go around Road Atlanta. going soon! | Page 4 | FerrariChat
Discussion in 'Tracking & Driver Education' started by Ferraripilot, Jun 28, 2013.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,922
    Atlanta
    John!
    The front end is noticeable sharper at higher speeds. Still not 100% sure yet though as I haven't had it in a track.
    I removed pretty much all of the lower fork shims to correct camber, I think it's a bit over 2.
  2. NSXLuvr
    NSXLuvr Formula Junior
    Oct 3, 2006
    575
    Tx
    Ritesh
    HAHA - True. After reading that thread and watching the video I was quite plesantly surprised.
  3. ktr6
    ktr6 Formula Junior
    Mar 25, 2011
    947
    Knoxville, TN
    Keith
    I may try to get the 348 there at some point. Would hope it's faster than my miata but I'm not holding my breath.
  4. JeffBarber
    JeffBarber Karting
    Feb 6, 2011
    175
    Lascassas, TN
    Jeff
  5. chris1866
    chris1866 Formula Junior
    Mar 14, 2005
    562
    Atlanta
    Chris
    MVP runs a good event. I'll be at the november one as well in my e36 m3 track car.
    I ran with them last november and this past June as well. As others have said, it's a very laid back and fun group to run with. You will have a great time.
    I'm putting my money on high 40s for the 308.
    I have a few friends that use Harry's laptimer and it seems to be hit or miss. If you can't get it working, you can borrow my AiM SOLO for a session.
  6. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,468
    VIR Raceway
    Peter Krause
    Use the Solo...
  7. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    you lost me here.. When I lowered the car the camber became kind of positive. I actually had to put the forks on longer struts to allow for more shims...
    I think we talk different things here:):)
  8. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    I must have worded it strangely. The additional camber I gained from lowering wasn't entirely dialed out. I kept a bit more than stock after driving it once corrected to stock specs.
  9. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    I'm probably going to run Harry's lap timer with an upgraded 10hz gps to make it work better. Thanks Chris, look forward to seeing you!
  10. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    but that's were you lost me:):) lowering a 308 will not gain camber (at least if you define gain as moving from plus to minus) but you actually loose camber. ( it will go from minus to plus)
    writing this down and re-reading it is indeed pretty strang loosing=more positive...)
  11. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    you're exactly right. everything I said was backwards. I had my camber vernacular off hah. thanks Steven!
  12. GuyIncognito
    GuyIncognito Ten Time F1 World Champ
    100,355
    #87 GuyIncognito, Nov 23, 2013
    so what's the lap time John?
    triple verified of course :p
  13. apex97
    apex97 Formula Junior
    Nov 25, 2006
    593
    Stockbridge, GA
    Edward Zabinski
    Perhaps you need a local pro driver to make a few laps to help with set up?:)
  14. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    Hey guys.
    Disaster struck just a day before going up to tech inspection. The damage is actually not that terrible in my eyes as I enjoy doing this sort of thing. I made a video of my progress which I will post, but I spent the other day removing the 1-4 bank head.
    Here's what happened: Downshifted a few times checking brake dive and stability under trailbreaking, the camshaft locking tab on the 1-4 bank exhaust cam snapped, exhaust bolt backed out, cam cog came loose, cylinders 1,2,3 all had minor piston contact. I remain baffled by this as I used red loctite and torqued that bolt to 85lbs. The good news is nothing else was damaged so I'm just replacing the valves, the bad news is I missed my long anticipated track day.
    I had just changed the oil/fluids and was out checking final tune and suspension set up, which was perfect by the way.
    The head is already apart and the parts should arrived this week. It could have been worse.
  15. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    #90 Ferraripilot, Nov 25, 2013
  16. GuyIncognito
    100,355
    oh man that sucks :(
  17. chris1866
    Mar 14, 2005
    562
    Atlanta
    Chris
    Sorry to see this.
    I ended up spending most of the weekend in the paddock with the car up on jack stands myself. Only ran a total of 4 sessions over both days. Shame because the weather ended up being good.
    Oh well, such is life! See you out there next time
  18. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    #93 Ferraripilot, Nov 25, 2013
    I saw the weather was perfect......
    Just removed the valve guides this morning. Fun.
  19. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Ouch!
  20. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    Sent an exhaust cam to be case hardened, one of the lobes had me concerned. It was the lobe which had the worst bent valve. I'm sure what happened was that for the very short time the engine did run, that lobe was lacking oil combined with the valve it controls already being partially open thus forcing a higher initial lift force on what was practically the nose of the cam. that's bad, it looks like it knocked the case hardening off right at the tip as I've measured it compared to the other lobes and it's only .0015 off. Could have been worse
  21. raider1968
    raider1968 F1 Rookie
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    I agree - ran once with Chin at Homestead last year - was not impressed at all - did not like the attitude of several people including a pompous instructor I had the misfortune to be with - I've had coaches(pro drivers) who would make the instructor look like a complete amateur and he actually thought he was hot s**t
  22. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,468
    VIR Raceway
    Peter Krause
    Hahaha! I DO understand that...
    I do some work with clients at Chin and the track time is good. Especially the 90 minutes at the end of the day ("Happy Hour") when my client and I can try several different drills, separated by short briefings. A good use of our time together.
