How long can a 328 sit before running the battery dead? | FerrariChat
Discussion in 'Technical Q&A' started by Jedi, Apr 19, 2008.
  1. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,322
    Seattle Area
    Dave
    Subject says it all - I have to travel for 2 weeks straight. Should I disconnect
    the battery (it seems strong) so the clock doesn't run it dead?
    Thanks,
    Jedi
  2. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    If the battery is good it will probably run the clock for months with no problem. In any event, if you leave it connected and find the battery is dead when you return you need a new battery (good to know now rather than later) or you have something else causing additional current draw (needing investigation).
    It's never a bad idea to disconnect the battery on a cars like these when it's only a matter of setting the clock again however I wouldn't want to mess with the clock too often. We should probably be greatful that they still work :)
  3. Jedi
    Jedi Moderator
    Mar 18, 2008
    32,322
    Seattle Area
    Dave
    No doubt! I was amazed it worked, and more amazed that the somewhat tweaky setting of it
    with that TINY knob still works!
    I promise to drive her the MINUTE I'm back in town
    :D
    Jedi
  4. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,347
    E ' ' '/ F
    Enzo Gorlomi
    The 328 has a quick disconnect for the battery behind the driver's headlight
  5. Jedi
    Jedi Moderator
    Mar 18, 2008
    32,322
    Seattle Area
    Dave
    Found it! Thanks!
    Jedi
  6. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy
    Eugenio Dalla Rosa
    Regrettably i have to leave my 328 sitting for several weeks at a time. Never a problem to re start her.
    Ciao
    Eugenio
  7. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Yeah, but there's something to be said for being reunited with an object or person that you love after a time apart. Makes it that much more special.
  8. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    I finally went out and bought a battery tender for mine. I used to have to lift the hood to get to the pigtail to plug it in but a couple months ago I moved it near the front hood strut and made a little hook tool to fish it out between the louvers when I plug the tender in.
