How Long Should a Battery Last? | FerrariChat
Discussion in 'Technical Q&A' started by Dom, Mar 1, 2004.
  1. Dom
    Dom F1 Veteran
    Nov 5, 2002
    8,489
    What's the typical lifespan of an automotive battery?
    Any signs that would indicate the battery is about to go out on you?
    I just replaced the battery on my Alfa (Not a ferrari, but I figure this thread pertains to ferrari's as well). I have had the car over 5 years with the same battery, and I think it was replaced about 2 years before I purchased it, so it was around 7 years old. Took a look at it this weekend (it's in the trunk, under a cover), and there was lots of gook around the battery. Looked like a mess. Went out and bought an optima, and replaced it, figuring it might be toward the end of its life, and I'd rather pay the money up front than have to pay for a battery and a tow later on.
    Dom
  2. tifosi
    tifosi F1 Veteran
    Sep 5, 2001
    5,382
    texas
    Tom D
    prob anywhere from 3-10 years, depends on type, if a battery is not secure they can fail earlier - seven years you should be happy on a italian car :)
  3. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,615
    Dallas, TX, USA
    Depends also on how regularly you use the car... typical lead-acid batteries last much longer if they are kept fully charged... they deteriorate when discharged significantly. Just the opposite of some other types of batteries.
  4. f355spider
    f355spider F1 World Champ
    18,029
    Would agree that in a "daily driver" situation, a battery that is topped up with fluids and terminals cleaned once a year will probably last 5 to 7 years no problem. Cars that sit a lot, without a battery tender, tend to go through batteries in a couple years.
  5. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,350
    Canada
    Newman
    I agree at 5-7 years. With the crappy winters up here if its 5-6 years old and still good, replace it anyway so you dont get stranded. 10 is rare.
  6. ROGER
    ROGER Karting
    Feb 9, 2002
    131
    Lake Havasu City, Az
    Roger Blakeman
    About 2 years in the desert!!!
  7. bobwass
    bobwass Karting
    146
    Los Angeles
    Bob Wass
    5 years is the max for most batteries.
    the higher quaility batteries that sell for higher buck$$
    with a longer warranty are the same batteries that sell
    for cheaper buck$$ with a lesser warranty.
    they are all the same battery. 5 years max.
    many considerations: heat, cold, charging cycle, vibration/
    physical trauma, etc.
    but they will all last, or should, for 4 or 5 years. any longer than that and
    you are in 'risk' mode.
    any shorter than that and you have a problem with an above listed consideration, or bad luck.
    other batteries with different constuction like optima mite have
    better resistance to failure/lack of charging/physical trauma
    than a regular lead-acid battery. but 5 years will probably
    still be a bite in the butttttttttttttttttttttttttttttttttttttttttt.
    how lucky do you feel?
  8. Wayne 962
    Wayne 962 Formula Junior
    503
    I typically tell people to replace their battery after five years, *if* they are having any problems. Some can last longer, some can last much less. A lot depends upon how many times you leave your lights on and let it run down to empty. Unless you have what is called a deep-cycle (marine) battery, then running it down near empty is typically very bad for it.
    -Wayne
