How make Tubi more quiet? | FerrariChat
Discussion in '360/430' started by Finpat, Jul 28, 2024.
  1. Finpat
    Finpat Karting
    Sep 17, 2021
    249
    Finland
    Kari Lehtinen
    I am getting old, hence the question, what would be the most cost efficient solution to make 360 Spider with non-valved Tubi quieter? It really is embarrassingly loud in urban environment, in open road life is good with Tubi.
    I have tried to search the solution but I only find information how to make 360 even louder...
  2. Scott98
    Scott98 F1 Rookie Owner Silver Subscribed
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    Buy a used stock muffler and swap it.
    E60 M5 likes this.
  3. s1owcoach
    s1owcoach Rookie
    Jan 17, 2021
    19
    Newcastle
    I’m sure factory tail pipes with valves fit in to the tubi back box
  4. Finpat
    Finpat Karting
    Sep 17, 2021
    249
    Finland
    Kari Lehtinen
    Would it be possible to reuse Tubi outlet pipes with stock muffler?
    Brand new OEM muffler wouldn't be too expensive. With used OEM muffler "the white dust" might hit too soon.
  5. Finpat
    Finpat Karting
    Sep 17, 2021
    249
    Finland
    Kari Lehtinen
    That would be another solution, there seems to be quite a few used valved outlet pipes for sale in Euro-zone.
    Can anybody confirm this for sure?
  6. Benjamino
    Benjamino Karting
    May 1, 2021
    58
    Dronfield, Derbyshire
    Benjamino Johnson
    The previous owner of my Modena fitted a Nouvalari system to mine and then realised it was too loud, so re-fitted the valved OEM tailpipes to it! Best of both worlds!
  7. priericky128
    priericky128 Formula Junior Silver Subscribed
    Feb 11, 2021
    693
    St. Louis MO
    Rick
    I have heard that oem tips will fit the tubi. I have not done it myself but plan to fit a pair this fall for the same reason as you mention in your post.
    The car is just too loud at low rpm for me.
    Depending on your timing I can let you know if they work.
  8. imahorse
    imahorse F1 Rookie Silver Subscribed
    Nov 25, 2017
    4,355
    WI
    Dustin
    Sounds like you want a valued exhaust.
    Sent from my toilet using FerrariChat.com mobile app
  9. swc5150
    swc5150 Formula Junior Rossa Subscribed
    Jan 5, 2021
    725
    Wisconsin
    Scott Calderwood
    I put the stock tail pipes back on my car to have valves. Too me the car was too loud inside to handle without them.
  10. Finpat
    Finpat Karting
    Sep 17, 2021
    249
    Finland
    Kari Lehtinen
    Great to hear I am not the only person who wants a slightly more tamed sound track.
    As there seems to be rather healthy availability of second hand stock valved outlets with reasonable pricing I will start with that.
    s1owcoach likes this.
  11. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,587
    I cut the stock valves cut out of the stock tips and had them welded into the tubi tips, its perfect now.
    (if you do this, be aware they are not perfectly a mirror image, one valve is in a slightly different spot than the other so place them just like stock)
  12. Johnv10
    Johnv10 Karting Rossa Subscribed
    Jun 16, 2018
    63
    Boerne Texas
    John Hackett
    I just installed Tubi headers and the Tubi sport exhaust with valves. It removes the big muffler in the engine bay and utilizes two mufflers down below right behind the exit ports in the bumper. It is suspended by a new bracket system with rubber isolators. Gets rid of the old bracket on the transmission. A win win!
  13. RedTaxi
    RedTaxi F1 Rookie Silver Subscribed
    Mar 1, 2012
    3,339
    New Zealand
    Glen
    I had a non valved Tubi. All the exhaust gasses go through the muffler. A valved exhaust simply bypasses the muffler when the valves open making it louder with better flow.
    I can't possibly see how adding valves would make it quieter.
  14. netsec
    netsec Karting
    May 5, 2022
    101
    Henderson, NV
    I contacted Tubi about this back in January. Their recommendation was to add the valved end tips (01239911020V).
  15. Exvetteguy
    Exvetteguy Karting
    Aug 5, 2012
    122
    Wolcott Ct
    Eric Schifilliti
    I Love My Tubi...Couldnt Imagine It Without The Exhaust...
  16. RedTaxi
    Mar 1, 2012
    3,339
    New Zealand
    Glen
    I guess I can see if you put valves in 2 of the 4 pipes then when closed you've choked it down to just breathing through 2, so it would be quieter.
  17. netsec
    netsec Karting
    May 5, 2022
    101
    Henderson, NV
    I tested by blocking the two outside pipes, where Tubi installs the valves. It was definitely quieter on a cold start…that’s where my neighbors get snippy at 6am when heading out to a cars and coffee. Still weighing the cost ($2500) versus the occasional apologetic bottle of wine .
    RedTaxi likes this.
  18. WashingtonFerrari61
    WashingtonFerrari61 Formula Junior
    Jun 26, 2022
    476
    Northern, VA
    I feel like my Tubi is too quiet at times. I have always been curious how loud is the stage 3 Capristo exhaust really? It’s hard to gauge the sound on a YouTube video but at my age, I think I would probably regret the switch.
  19. RedTaxi
    Mar 1, 2012
    3,339
    New Zealand
    Glen
    Aahh, that above relates to my 430. My previous 360 is different as when valved it simply blocks 2 pipes rather than bypassing the muffler.
  20. Finpat
    Finpat Karting
    Sep 17, 2021
    249
    Finland
    Kari Lehtinen
    Early morning cold starts during the weekend and drive through the quiet neighbourhood with non-valved Tubi are not giving a "good neighbour" vibes, agreed.
    I think, I start to experiment 250€ used valved OEM outlets.
  21. Finpat
    Finpat Karting
    Sep 17, 2021
    249
    Finland
    Kari Lehtinen
    Thanks for the guidance!
    As I don't have OEM tips I might actually look some 3rd party butterfly valve solution.
    Something in vein: https://www.futurez.fi/en/shop/exhaust-system/universal-exhaust-parts/exhaust-flaps/exhaust-system-valve-universal-76mm-vacuum-operated/
    Or same valve from China Inc. https://vi.aliexpress.com/item/4000833485122.html?spm=a2g0o.productlist.main.49.1c59teTAteTAFS&algo_pvid=bd799cdb-01dd-416f-b13f-b7176fb6e0de&algo_exp_id=bd799cdb-01dd-416f-b13f-b7176fb6e0de-24&pdp_npi=4%40dis%21EUR%2127.15%2120.72%21%21%2128.61%2121.83%21%40211b8c6317227575644714061e538f%2110000008698064282%21sea%21FI%210%21ABX&curPageLogUid=Y4B7Qc3Qyzt6&utparam-url=scene%3Asearch%7Cquery_from%3A
