how many miles before to change the brake disc rotors? | FerrariChat
Discussion in 'Mondial' started by BlackMondial32, Dec 15, 2013.
  1. BlackMondial32
    BlackMondial32 Karting
    Aug 27, 2007
    244
    50k ? 100 k ?
    2 k ?
  2. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    I'd say that it's based on thickness measurement. Also, warpage (distortion) would be a factor. Don't believe it holds to any particular mileage number.
    Cheers, Hank
  3. afterburner
    afterburner F1 Rookie Silver Subscribed
    Jun 20, 2008
    3,470
    Switzerland
    Urs STEMMLER
    Depends how you brake.Mine are above minimum thickness and not warped at 100K.
  4. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    At 70K miles mine were badly grooved and were turned down to minimum spec showing just a tiny section of one groove. Totally usable for another ?? miles. I chose to go with new rotors instead of using the min thickness rotors.
    So like others said, depending on use it's somewhere between cracking them on a race track and infinity. Depends on the user. I expect the rotors that I just put on to last the lifetime of the car. Just don't let the pads get too low.
  5. afterburner
    Jun 20, 2008
    3,470
    Switzerland
    Urs STEMMLER
    And my pads haven't been changed in the last 70K... The booster needed replacing about 5 years ago.
  6. ozmondy
    ozmondy Formula Junior
    Oct 30, 2013
    307
    N.T, Australia
    Peter
    Mine have recently been changed as the pads look almost new and I show 70k kilometres not miles.
    Still got original rotors
