How many of you Mondial guys only have one fan? | Page 2 | FerrariChat
Discussion in 'Mondial' started by Birdman, Jun 30, 2008.
  1. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    My 89 has 2.
  2. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    My '87 3.2 has two fans.
  3. ssrealty
    ssrealty Formula Junior
    Sep 12, 2010
    325
    Austin, TX
    Chris Warren
    My 85 QV has ONE fan. I think the 3.2 Mondials have 2 fans.
    Also what is average of temperature gauge on engine and cooling system? My car runs right at 195 on highway. In traffic on hot days in TX, it will be a little past 195. The engine oil temperature will hit about 210 at constant speeds.
  4. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    #29 Jeka, May 9, 2011
    The average water temperature is 70 degrees Celsius (158 degrees Fahrenheit), the average oil temperature is 80 degrees Celsius (176 degrees Fahrenheit). This is after a few hours of driving, the ambient temperature was 21 degrees Celsius (70 degrees Fahrenheit). Don't look at the oil pressure (the pressure sender seems to be faulty).
  5. dennis_maine
    dennis_maine Karting
    Sep 11, 2007
    206
    ME
    Dennis Haines
    My 1981 M8 has only one radiator fan, and it runs cool, if anything, at laeast according to the gauge.
  6. porphy
    porphy Formula 3
    1,210
    LouisvilleKY/Switzld
    Randall Gatz
  7. Mfoncerrada
    Mfoncerrada Formula Junior
    Dec 20, 2009
    419
    Monterey, CA
    Miguel Foncerrada
    Hi Bridman, Do you have a part number for the fan you bought?
    tnx
  8. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    My 84 QV has two fans.
    Though the second one on the passenger side appears to be "added" as the bracket that holds it to the radiator appears to be "glued" on it and it is loose.
    I never had a cooling problem, even in hot California weather in stop and go traffic. The needle does go beyond the middle range in extreme conditions, but never even close to hot.
    Both fans start and stop at the same time.
  9. Subito Grigio
    Subito Grigio Formula Junior
    Jun 2, 2009
    405
    I recently bought a used fan for the car which already has the posts/studs for mounting two fans. As said previously - car is already wired for two fans.
    Car tended to run hot because of fusebox delamination which allowed only partial single fan operation. Silly me, I thought it was the thermostat...
    "When you think it's butter - but it's not" - it's the G. D'd. delaminated FUSEBOX.
    [from an old Chiffon Margerine ad. I remember the ad because I'm old!]
  10. Subito Grigio
    Jun 2, 2009
    405
    #35 Subito Grigio, May 11, 2011
    I recently bought a used radiator for the car and a second fan. The used radiator already has the posts/studs for mounting two fans. As said previously - car is already wired for two fans.
    [from an old Chiffon Margarine ad. I remember the ad because I'm old!]
  11. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    #36 afterburner, May 20, 2011
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    #37 afterburner, May 20, 2011
    Mondial Radiator Fan Motor Replacement Cross Reference, should you not be able to source an original motor... (only the electric connector needs to be adapted, the rest is plug'n'drive):
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    #38 afterburner, Jun 1, 2011
  14. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    #39 afterburner, Jun 1, 2011
  15. porphy
    porphy Formula 3
    1,210
    Randall Gatz
    Are the motors the same across the Mondials? (8,QV, 3.2, T)
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    The radiator fan motor part# 117546 is used on the Testarossa, 328, 512BBi, 288, 208 turbos and ALL Mondial versions (incl. as a condenser fan motor on the 8).
  17. DenisB
    DenisB Formula Junior
    Jul 21, 2007
    511
    Cape Cod Ma.
    Denis B.
  18. DenisB
    Jul 21, 2007
    511
    Cape Cod Ma.
    Denis B.
  19. jgoodman
    jgoodman F1 Rookie
    3,273
    Central PA
    Jay Goodman
    Does that really say 156K km! Awesome!
