How Many U.S. 1995 Berlinettas? | Page 5 | FerrariChat
Discussion in '348/355' started by JSinNOLA, Aug 13, 2024.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,187
    Southern California
    Nostradamus
    *98673 & 98674 have Feb 94 build dates, not Oct 93.
    The first F355 ever was built in Oct. 93.
    According to some records, 98673 & 98674 are the 6th & 7th 355’s ever produced (world wide).
  2. MK355
    MK355 Karting
    184
    M K
    101658 here
    February 1995 build
    Rosso Barchetta over Tan
    ShineKen likes this.
  3. MK355
    MK355 Karting
    184
    M K
    I see mine on the 5th page :)
    I see a lot of discussion as to which cars had the dual pumps vs single, but not a lot of discussion as to why or the advantages/disadvantages
  4. ShineKen
    20,187
    Southern California
    Nostradamus
    My guess for the switch would be simplification. Perhaps the single pump is a higher spec pump and adequate eliminating the need for 2.
  5. Buckets
    Buckets Karting
    Sep 9, 2019
    130
    Seattle, United States
    Nick Papagiorgio
    100498 here. It's a nero/nero GTB. I had no idea it was in the first hundred made and on the second page of this recall list. :) I think it is a September or October 1994 build date but I'll need to check. It's a dual pump but it has a two piece undertray, not a one piece.
  6. ShineKen
    20,187
    Southern California
    Nostradamus
  7. ShineKen
    20,187
    Southern California
    Nostradamus
    We know at some point in Sept 94, the switch was made from single-piece center undertray to the new 2-piece design. We just don’t know which VIN is the last single-piece.
    The good news is your car is a Nero/Nero 95, which is incredibly rare. 355Registry only shows 11 (worldwide) at the moment, but keep in mind the registry has already captured 45% of 355’s produced. Perhaps @Matthias Urban can give us a better idea.
    The second good news is you made the cutoff for the early engine goodies :).
    Buckets likes this.
  8. ShineKen
    20,187
    Southern California
    Nostradamus
    Very early cars are also supposed to have the first clutch cover/cooler design. I see most people no longer have it. Either destroyed or removed and misplaced as it was unsightly. One of the first things I removed when I received my car. It is no longer available from Ferrari.
    Wonder how many are interested in obtaining this?
    I am also not exactly sure at what stage Ferrari stopped including it.
  9. ShineKen
    20,187
    Southern California
    Nostradamus
  10. ShineKen
    20,187
    Southern California
    Nostradamus
    Barry’s car is #100330 and has the single-piece tray and a Sept. 94 build. Perhaps we’re getting closer to an answer.
    Buckets likes this.
  11. Buckets
    Buckets Karting
    Sep 9, 2019
    130
    Nick Papagiorgio
    That is cool! And the cutoff might explain why it runs so strong. I know my heads are the 2154014 castings from June/July 1994 so I guess those are the supposed "good ones." I could weigh my pistons and rods when they are taken out to see if they are lighter ones. Otherwise I don't know what else is different on the really early cars. Maybe cams?
    308 GTB and ShineKen like this.
  12. ShineKen
    20,187
    Southern California
    Nostradamus
    https://www.ferrarichat.com/forum/threads/cool-find-f129-engine-for-360modena-transmission-test.696408/
    Cams should be same imo. Perhaps different porting, but we kinda need a side by side to a non-early engine to really confirm the differences.
    My car runs strong as well. Probably the reason Fchatters look at me like I have 2 heads when I’ve been telling them the past decade a 355 is a decently quick street car. It still feels heavier than what I’m used to, but if one can remove 400lbs … watch out!
    308 GTB and Buckets like this.
  13. ShineKen
    20,187
    Southern California
    Nostradamus
    Biggest drawback of the early engines is the softer bronze guides imo. But that’s an easy fix once engine is out. #100594’s guides were replaced by a previous owner with factory steel guides and the car feels pretty damn good. Better than 99902, which still has original guides.
    308 GTB likes this.
  14. ShineKen
    20,187
    Southern California
    Nostradamus
    @Buckets
    This is early car #099948 Nero/Nero vs. 458 Speciale just in case you didn’t catch it. Decent acceleration given the weight (3200 lbs).
  15. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,955
    Richmond
    Pete
    And mine has the two piece tray, so the cutoff would appear to be right around our cars - 100330 (single piece) and 100329 (2 piece).
  16. ShineKen
    20,187
    Southern California
    Nostradamus
    If Barry is the last 355 to receive it, we have roughly 45 U.S cars that came equipped with the single-piece tray. Unless of course one of the employees found a single-piece in the back corner somewhere and shop boss said, “just put it on the challenge car.” :)
  17. ShineKen
    20,187
    Southern California
    Nostradamus
  18. ShineKen
    20,187
    Southern California
    Nostradamus
    100594 - ShineKen
    100606 - INTMD8
    100607- ???
    100608 - mclaudio. F355 Challenge.
    A small clutter of N/A Red/Black 355’s. Quadruplet siblings.
    Buckets likes this.
  19. Matthias Urban
    Matthias Urban F1 World Champ
    Mar 5, 2005
    10,214
    Germany
    Matthias Urban
    In Nero 1240 DS I show about 40 units worldwide. There are as well examples in Nero Carbonio (metallizzato, that became Daytona later) and as well examples simply being discribed as being Black/Nero because "Black" was not specified with a Factory colour code already ;)
  20. ShineKen
    20,187
    Southern California
    Nostradamus
    You’re referring to 2.7’s specifically correct? Any pre-airbag Nero/Nero cars? Don’t think I’ve come across one yet.
    You also have 100607 as Nero/Nero, but the 355Registry shows that as Red/Black. It is surrounded by Red/Black cars as shown above.
  21. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Yes, the single piece tray could have been put on my car which was destined to be a Challenge car.
    Another possibility is the cut-off point is based on Assembly Number.
    Pete, my car is S/N is 100330 It's Assembly Number is 17280
    Your car is S/N 100329 What's its Assembly Number?
  22. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    This thread is making me dizzy. :D
    All I know is that my car has the ugly rear bumper to add to its five or six shades of yellow, sandblasted fender walls, road-rashed front bumper, yellowing Challenge badge, sagging driver's side view mirror secondary to its roll onto its roof at Lime Rock Park in 1996, rubbed Challenge wheels, peeling/patinaed cam covers and jack-dinged doors.
    If I continue reading threads like this, I'm sure I'll discover more things wrong about my car. :)
    Still, it remains a great race car...
  23. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    Uh-Oh! It looks like I've lost a fastener or two on my driver's side lower underbody guard. Something else that has to be fixed. My undertray, lateral guards and diffusers have several varieties of fasteners holding them in place. Tracking the car shakes them loose periodically, especial Sebring. I'll never know what the OEM fasteners looked like. But that's okay. :)
  24. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,955
    Richmond
    Pete
    Mine is 17273.
  25. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,955
    Richmond
    Pete
    I believe mine has the tall toolbox - has a huge can of fix a flat in the bottom exactly as you've pictured.
