How Many U.S. 1995 Berlinettas? | Page 6 | FerrariChat
Discussion in '348/355' started by JSinNOLA, Aug 13, 2024.
  1. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    So it doesn't go by Assembly Number. Ken is probably right. They had the single piece undertray on the side somewhere in The Factory and put it on my car.
    But maybe your undertray was replaced along the way with the two-piece undertray.
  2. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,953
    Richmond
    Pete
    I think I'd rather the challenge piece, much nicer looking and appears to functionally cool the clutch, though I never had any clutch issues on track, brakes were the bigger issue. I didn't think anyone is pounding these around for 30-45 minutes flat out at this point to need it.
    Could be. I have service history going back to 2001 and it wasn't mentioned at any point going back that far, but the front bumper has been repainted and scraped again, and the current under tray is far from pristine. It was run really low with god awful 21" wheels prior to me getting it.
  3. ShineKen
    ShineKen Two Time F1 World Champ
    20,182
    Southern California
    Nostradamus
    Maybe the undertray allocation wasn’t that exact.
  4. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    Most likely. In September 1994, whatever version of undertray was nearby was put on the car.
    The two-piece undertray was cheaper to make, hence the "New Solution."
    ShineKen likes this.
  5. ShineKen
    20,182
    Southern California
    Nostradamus
    With the single-piece undertray, on a lift, all one had to do is remove 4 screws to remove the small square panel, reach in with a tool to get to the oil drain. Problem is you need a custom funnel to make sure oil doesn’t get everywhere when it shoots out. I’m sure dealers complained, hence the new 2-piece solution.
    308 GTB likes this.
  6. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    For those not familiar with the Challenge clutch cover, it looks like this...
    Heat-reflective material provides heat-shielding. Holes drilled in the clutch housing along with scoops on the cover provide internal clutch cooling at speed.
    It's made of thin fiberglass but has held up well.
  7. Matthias Urban
    Matthias Urban F1 World Champ
    Mar 5, 2005
    10,214
    Germany
    Matthias Urban
    thanks for making me aware, Ken, you are correct and I have pics to prove that Rosso Corsa is the right colour for 100607. Record corrected, to be shown with the next update
  8. ShineKen
    20,182
    Southern California
    Nostradamus
    How many U.S Nero/Nero 95 B’s in your data?
  9. Matthias Urban
    Mar 5, 2005
    10,214
    Germany
    Matthias Urban
    6 in Nero 1240 DS Glasurit/Nero 8500 and 4 in non-specified Black/Nero 8500
    For the total split I still wating for a dozen VINs to finalize ;)
    Buckets and ShineKen like this.
  10. ShineKen
    20,182
    Southern California
    Nostradamus
    I haven’t seen any Nero Carbonio’s/Nero’s in the U.S, so chances are they’re all Nero/Nero. 10 cars only? Out of 370? I’ll take it :).
  11. Matthias Urban
    Mar 5, 2005
    10,214
    Germany
    Matthias Urban
    no 95 Berlinetta in US-spec. claims to be Carbonio :)
  12. ShineKen
    20,182
    Southern California
    Nostradamus
  13. Matthias Urban
    Mar 5, 2005
    10,214
    Germany
    Matthias Urban
    yes I had to be more precise... ;) no 95 Berlinetta in US-spec. claims to be Carbonio with Nero interior :)
  14. ShineKen
    20,182
    Southern California
    Nostradamus
    @Matthias Urban
    I believe you have my car 99902 as TDF/Crema. It’s Nero/Nero ;).
  15. ShineKen
    20,182
    Southern California
    Nostradamus
    Got a gem for ya ;).
    308 GTB likes this.
  16. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
  17. ShineKen
    20,182
    Southern California
    Nostradamus
    308 GTB likes this.
  18. ShineKen
    20,182
    Southern California
    Nostradamus
    308 GTB likes this.
  19. ShineKen
    20,182
    Southern California
    Nostradamus
  20. Matthias Urban
    Mar 5, 2005
    10,214
    Germany
    Matthias Urban
    no, Ken, db has it correctly as Nero/Nero :rolleyes:
  21. ShineKen
    20,182
    Southern California
    Nostradamus
    Ok. Then it was corrected. Thank you.
  22. ShineKen
    20,182
    Southern California
    Nostradamus
    ZFFPR41A3S0100228
    Anyone own #100228 ??
  23. phrogs
    phrogs F1 Veteran
    7,375
    Kzoo Michigan
    I can say for sure Vin ZFFPR41A6S0100689 is destroyed. Dual pump
  24. ShineKen
    20,182
    Southern California
    Nostradamus
    Description?
  25. Matthias Urban
    Mar 5, 2005
    10,214
    Germany
    Matthias Urban
    Rosso Corsa/Beige, manual with Nero calipers
