How Mercedes solved their rear tire issue | Page 2 | FerrariChat
Discussion in 'F1' started by Ferraripilot, Jul 31, 2013.
  1. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,290
    Not if it was just a recessed groove vs an actual slot.
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,961
    Atlanta
    John!
    I have to disagree. The duct on the Benz is channeled so differently than any other team, and I'm still not seeing that same rear inner wheel treatment on other teams rear rims.
  3. freshmeat
    Aug 30, 2011
    7,290
    They all have openings that feed air to the wheel, look for the vents some way, you'll see them. Same principle, different executions. Try googling it, I'm pretty sure something will come up, I'm too lazy to highlight them again...I posted them up before somewhere.
    Here's Ferrari's from awhile back:
    http://scarbsf1.com/blog1/wp-content/uploads/2012/07/scoopless_FBD.jpg
  4. LightGuy
    LightGuy Four Time F1 World Champ
    Oct 4, 2004
    46,160
    Texas
    David
    I'm trying to come up with a reason they would have tape on the inside of the rim.
    Everything that comes to mind is a liability or patch for poor engineering in the first place.
  5. Ferraripilot
    May 10, 2006
    17,961
    Atlanta
    John!
    #30 Ferraripilot, Aug 2, 2013
    Ferrari left, Sauber center, Lotus right. All rear wheels. I suppose Ferrari may have a similar idea going but on a much smaller scale. I just cannot deduce why Merc would put 'tape' or some material on the inside of the rim and not a cut out as is conjectured. Still lots of debate on this. I love F1!
  6. freshmeat
    Aug 30, 2011
    7,290
    It's tape. Why are they using tape? Beats me, best guess is it might be like that heat-retardant wrap that some folks put around their exhausts, so when mounting & dismounting the wheel doesn't fuse with the drum.
    I ran it by a friend, who makes forged alloy wheels, at dinner last night and he said structurally if there was such a deep slot running the full circumference of the wheel, the strength of the metal would be severely compromised and would very unlikely be able to withstand the loads and stresses of a regular car let alone an F1 race car.
  7. Ferraripilot
    May 10, 2006
    17,961
    Atlanta
    John!
    very interesting, thank you for asking him!
  8. freshmeat
    Aug 30, 2011
    7,290
    Just finished reading new posts on F1tech and read this:
    From Tobias Gruner Auto Motor und Sport :
    "Teams to seal the brakes and reduce heat transfer to the tires use special band made of rubber or Teflon. The elastic element is subjected to forces acting on the wheel while driving exactly filling the space between the hub and the rim. Most teams found the band on the hub, but Mercedes, for unknown reasons, yet I decided to put it on the rim."
  9. Ferraripilot
    May 10, 2006
    17,961
    Atlanta
    John!
    I bet Merc found they could reduce temps further by placing the band on the inner rim instead? Thus reducing a greater amount of brake disc heat transfer to the rear tire. Makes sense, especially if they're doing everything they can to keep heat out of those tires.
  10. Neonzapper
    Neonzapper F1 Rookie
    Oct 19, 2008
    2,580
    MD/FL/Philippines
    Mykol
    #35 Neonzapper, Aug 3, 2013
    I noticed Lotus painted the inside of the wheels with matt black finish...probably to diffuse the image from photos.
    So, it would make sense to be a rubber ( not tape which would block) shield which probably covers tiny vented slots for the transfer of cool air inside the tires, while trapping heat in the brake area. I wouldn't be surprised if the vented slots under the rubber band were shaped like a cheese grater for greater air flow direction.
  11. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Anything that made a wheel rim heavier than it needed to be would never be used, thus the theory of a hollow double layered section never happened.
    Pete
  12. Neonzapper
    Oct 19, 2008
    2,580
    MD/FL/Philippines
    Mykol
    What if it weren't heavier because it was a double layer of carbon fiber? (Devil's Advocate)
  13. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Then a single layer of carbon fibre would be lighter ... and less unsprung weight.
    Of course everything is a compromise ...
    Pete
