How much do you personally fix? | Page 2 | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by ernie, Mar 26, 2005.
  1. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    put a clutch in my f512m fitted sports exhaust will have a go at anything EXCEPT BELT SERVICE
  2. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    ROTFLMFAO !!!!!
  3. scorpion
    scorpion Formula Junior
    Jan 19, 2004
    469
    Kentucky
    I've done the timing belts and tensioners, spark plugs, water pump, thermostat, hoses, oil change and lastly installing a new oil cooler this week. I'm certainly not a mechanic but the 308's are really simple cars to work on. The only hard thing is just reaching or squeezing in or under to reach something. I'll give anything a try as long as I don't have to pull the engine and I absolutly hate trying to track down electrical gremlins.
  4. 123larry
    123larry Rookie
    Dec 11, 2004
    45
    Manteca,ca
    Larry Wiertel
    Hi,
    I rebuilt one of the rear brake calipers, and installed a rebuilt alternator. I get a lot of satisfaction from the work. The car is built with close quarters so you have to be a contortionalist. This forum and their support helps a lot. The tips are valuable and timesaving.
    larry
  5. Modenafan
    Modenafan F1 World Champ
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    I put my own air in the tires and I'm only marginally qualified to do that.
  6. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    The list is shorter if I list what I have not done.
    I have not painted the car.
    Have not rebuilt the transmission.
    Have not done any brake jobs.
    I have done just about everything else.
  8. 1975gt4don
    1975gt4don Formula Junior
    Nov 5, 2003
    665
    Peoples Rep of CA
    Smog Exempt
    Same here except I have done my entire brake system completely from end to end and have not done my own upholstery work. :)
  9. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    I did upholstry; it's called a piece of friction tape!
    Ken
  10. Llenroc
    Llenroc F1 Veteran
    5,560
    Colorado
    Vern
    I have owned Ferraris for twenty years and have done almost every thing that needed to be done from pulling a few 308 motors for various reasons to clutches on 512 Boxer to timing belt, 30000 mile service, on my 348 and 355C. The list is to long and I have enjoyed every minute of it, well almost, they are Italian cars. It seems to me that working on/maintaining these cars is part of the mystic of owning such a piece of mechanical artwork. IMHO if your going to own a ferrari you need to experiance it to the fullest, be part of it.
  11. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    How does getting the engine from the trunk (in pieces) to the engine compartment and running qualify? :D
  12. garysp7
    garysp7 Formula Junior
    Mar 28, 2004
    436
    Florida
    Gary
    I must say I'm impressed with you guys in your ability and dedication to working on your cars. I put gas in mine and call the tow truck a lot.
    I really enjoy driving my car but hate the thought that I might take it apart and not get it back together. I have found in the past that when I have to fix things (anything around the house) I usually end up having to call someone to fix what I tried to do, so i don't even try anymore on anything. I figure it is a waste of my time. There is less satisfaction that way, but I am not frustrated at having wasted my time and it not being right after.
  13. freindhas348
    freindhas348 Rookie
    Jun 17, 2016
    1
    At this time im helping a friend with one hes had less than two weeks!!Hes getting up there in years and he has created a couple problems...He broke the valve for recirculating air conditioning., among a couple of other things..........Im trying to see if it can be replaced or fixed..thanks anybody????lol
  14. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Post this in the 348 or Tech section.
  15. skierlawyer
    skierlawyer Formula Junior
    Sep 12, 2010
    385
    Golden, CO
    Brian
    On my F355 Spider:
    -Motor oil Change
    -Gear oil change
    -Replaced brake pads
    -Installed test pipes and new muffler
    -Replaced top-ecu
    I have a 4-post lift and hand tools, no air-compressor.
    I will have a reputable independent shop do my major service this winter. I don't have the time for it and it's above my skill level.
    I do a search on this site before I attempt anything to get valuable tips.
    Maintaining your own Ferrari is VERY rewarding.
  16. mwr4440
    58,067
    Bavaria, The 'Other' Germany
    Mark W.R.
    Tommy,
    Adjusting the valves and timing it is EASY.
    Motor-In makes it a PITA, BUT it is Easy.
    Rewinding a window is harder.
  17. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    I've done (in order):
    Coolant change
    Oil change
    Gear oil change
    Water temperature sensor repair (sensor not very easily accessible, deep underneath the plenum)
    Seals r&r in the clutch
    Assisted with the major service in a buddy's garage
    I have no background in auto repair but like Ernie I enjoy the challenge and learn quickly.
  18. blackbolt22
    blackbolt22 F1 Veteran
    5,809
    Boca Raton, FL
    Mr. Anderson
    I check the tire pressure and add air if needed.
