How much gain is a res delete + tubi boxes? | FerrariChat
Discussion in '456/550/575' started by Salami, May 25, 2021.
  1. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Just curious because I’ve read about some outlandish claims of power gains from these mods on a 456gt. I have the straight pipe res delete and tubi cans. Also, how much would adding hi flow cats gain? And what do they cost? Can’t find much in the way of dyno charts on this car.
  2. Davidspop
    Davidspop Formula Junior
    Dec 23, 2019
    401
    Lance Malcolm
    Would love to hear your exhaust... I have the Tubi cans... but have not pulled the trigger on straight pipes to replace center resonator!
  3. white out
    white out Formula 3
    Mar 3, 2010
    1,289
    If the center muffler on the 456 is the same used on the 550/575 then there is power to be gained as the pipe is crimped down to 2" from 2.25" at the exit of the muffler. Swapping out the rear mufflers is more for sound and weight reduction.
    I haven't seen much on high flow cats for the 456/550/575. Would likely need to fabricate some downpipes with high flow cats. This would also greatly increase the volume of the exhaust.
  4. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Huh, I read somewhere there was a direct high flow replacement that was cheaper than oem also. Maybe discontinued.
  5. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    I like the sound, the car does have a drone now but it doesn’t come in until after 3k rpm and that puts you around 90 in top gear so it’s not terrible for speeds under that. It’s not loud at all with this combo, but does have a bit of a growl.
  6. Mirek
    Mirek Formula 3 Silver Subscribed
    Oct 20, 2019
    1,495
    Los Angeles, CA
    Mirek
    philfrench and Ferrari55whoa like this.
  7. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Might not look restive but it still is with the perf metal. And there’s a very slight neck that reduces to closer to 2”. It’s barely noticeable. It’s the screen that is causing drag.
  8. Davidspop
    Dec 23, 2019
    401
    Lance Malcolm
    @Salami any "seat of the pants" torque feel? Or just a slight sound difference?
  9. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Maybe a little? I dunno. I also went from K&N to oem air filters at the same time so I might have lost the gains there.
  10. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    I’m tempted to weld a tiny crossover tube like 1/2” or less to see if it quells the drone but I’m afraid it will hurt performance.
  11. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,191
    Fabio uses two small crossover/balance tubes on his H pipe. Does not affect hp too much, but makes a big difference in resonance.
    philfrench and Salami like this.
  12. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Interesting. Using two would help stabilize the assembly for sure. Did they do any science type stuff to arrive at that or is it just a shoot from the hip sitch?
    Davidspop likes this.
  13. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    It seems like it would only take a tiny crossover to kill the drone. Maybe even 1/4” tube or two.
  14. tazandjan
    39,191
    Look on Fabio's site and there should be an image of his H pipe.
  15. Mirek
    Oct 20, 2019
    1,495
    Los Angeles, CA
    Mirek
    philfrench, Davidspop and Salami like this.
  16. white out
    white out Formula 3
    Mar 3, 2010
    1,289
