How much gas does this thing hold? | FerrariChat
Discussion in '308/328' started by Crallscars, Jul 18, 2006.
  1. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Ok I have only 400 miles on the 85 308GTS in 4 months, and have put gas in it a few times, but when the gauge reads near empty I have to assume its low, but I only put 8 or 9 gallons in it, I thought it was larger with a resurve? is the other 8 gallons when it hits "E" ?
    Doug Crall
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,666
    South East
    Jimmie
    I was told the tank holds about 21 USG but the light flickers when it feels like it and that the basic rule is once it is on solidly you have 50 miles - do not take this as gospel until you have double checked it however !
  3. Crallscars
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Light?
    I guess thats in the owners manual .......
    so how far can you go on "E" before the light goes on?
    I have yet to do a mileage test, what kind of milage does it get?
    Doug
  4. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    (Said in truth and humor) Well, that all depends if you are taking a hard right or a hard left turn at the track when the light comes on. If it is a hard right and coming on, you better gas up soon. If it is a hard left and the light just flickers on you got about a 1/4 tank+.
    Ok, smarta$$ mode off. These are hand built cars and i have a feeling the 'basic' assessment is that at a stop light if the light just starts coming on you have about 1/8th a tank (50 miles or so is a good guess as greyboxer mentioned).
  5. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    In search of a more dependable fuel gauge reading, I replaced the sending unit. No difference. When full, my guage reads above "F." Any motion up, down, left or right can cause swings of as much as 1/2 tank. My odometer is my gas guage. I also use it as a diagnostic tool, calculating mpg each time I fill up. I get between 14 and 16 mpg with a mix of freeway and "spirited" driving. I generally gas up at around 200 miles, which ends up being a little more than once a month :(
  6. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,599
    Gates Mills, Ohio
    Jon
    Same here. I reset my trip odometer on the 328 when I fill the 20-gallon tank. I don't let it get much below 1/3 tank and I try to add 10 gallons so it's not too full.
    The gauge fluctuates too much, dakharris said, to inspire much confidence.
  7. John Harry
    John Harry Formula Junior
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    My experience with my ’83 QV is similar. Owner’s manual says the tank holds 18.5 gallons; the warning light starts to flicker with around 5 or 6 left, except with hard cornering, when it may flicker almost anytime. I’m getting around 13 or 14 mpg. Using the odometer to double-check when it’s time to fill up gives some extra peace of mind.
    When I bought the car the gauge would register empty when it was half full, due to a bad tank sender. See http://www.ferrarichat.com/forum/showthread.php?t=86985 for details.
  8. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    My 89 328 holds 18 gallons---2-- 9 gallon tanks!
  9. Mondialmike
    Mondialmike Karting
    Mar 12, 2005
    217
    London
    Mike Hunnisett
    John, Is that 18.5 Imperial Gallons? = 22.2 US gallons.
  10. John Harry
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    Mike:
    The manual says 18.5 “U.S. Gallon” or 70 “Litri”. At around 3.79 liters per U.S. gallon, 18.5 gallons = 70 liters so it seems correct (or at least consistent). It also says the reserve is 4 U.S. gallons or 15 litri. I’ve never run it to empty so don’t know the actual capacity.
  11. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    my gauge needle doesn't function but the lite does. to be safe i put 20 or 30 in whenever i go for a drive and i keep a gallon plastic can in the trunk, an old habit from my vw days.
  12. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    FYI, I had a failure in the wire behind the dash for the gauge. Spliced in a new wire where it passed near the fuse box, then ran that to the back of the IP. It was a surprising diagnosis!
  13. Bullfighter
    Jan 26, 2005
    22,599
    Gates Mills, Ohio
    Jon
    I think this right. My Jeep holds 20 and I might have been confusing the capacities.
  14. John Harry
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    Maybe none of my business, but I’d reconsider this idea. Gas tanks are at least theoretically designed to maintain integrity in a crash; gas cans in the trunk are not. A gallon of gas going up in a fireball can kill you.
  15. tatcat
    Sep 3, 2001
    11,013
    rick c
    not only kill me but it would ruin my new paint job. don't worry it's empty. i keep it because they won't let you fill your pockets to carry gas back to the car:). don xvi...po had dash recovered so there's probably a wire pinched somewhere in there.
