how much my mechanical restore costed? | FerrariChat
Discussion in '308/328' started by Albert-LP, Aug 4, 2016.
how much does it cost?
  1. less than 20 K euro
  2. from 20 to 30 K euro
  3. from 30 to 40 K euro
  4. from 40 to 50 k euro
  5. from 50 to 60 k euro
  6. more than 60 k euro
Multiple votes are allowed.
Results are only viewable after voting.
  1. Albert-LP
    Albert-LP F1 Veteran Owner Rossa Subscribed
    Sep 1, 2010
    8,177
    around Modena, Italy
    Alberto Mantovani
    yesterday I went to my mechanic to close the deal of the restore: the work is done, the car now just needs to be reassembled. He did me the final cost, including the final assembly and check.
    The work includes a tons of things and pieces, here below there are the main ones.
    Valves: new (all)
    valve seats: new (all)
    valve guides: new (all)
    crankshaft: polished
    crankcase: machined
    crankshaft and crankcase bearings: new (all)
    clutch: new
    gearbox: new synchros (all) and new bearings (4)
    diff: new
    muffler: new stainless steel Tubi
    waterpump: new
    belts and tensioners: new
    spark 'plug cables: new (all)
    spark plugs: new (all)
    distributors: one new and one serviced
    engine sensors: new (all)
    oil pressure sender: new
    turbocharger pressure tube: new
    A/C compressor: new
    brake discs: new (all 4)
    brake calipers: fully rebuilt and plated
    brake pads: new (all)
    brake pump: new
    brake depressor: rebuilt and plated
    brake depressor ducts: new
    brake ducts: new (all)
    water radiator: fully rebuilt
    shock adsorbers: fully rebuilt (all 4)
    front suspension springs: new
    supensions: new joints, new bushings (all of them), painted, nuts and bolts plated
    steering rack: new
    water hoses: new (all, including a metal one)
    cabin air duct from the blowers: new and sealed the passages
    engine bay: repainted
    fuel tanks: cleaned and repainted
    fuel lines: new
    fuel pump: new
    fuel accumulator: new
    engine mounts: new
    water nourice: new
    engine and engine bay nuts and bolts: all new or plated
    lamps lights: all new
    fuse boxes: new
    main battery cable to the starter motor: new
    starter motor: rebuilt and plated
    alternator: rebuilt and plated
    central lock system actuators: new
    electric plant: checked and fixed (all), old mess done with an antitheft system removed
    wastegate valve: serviced
    turbocharger cooling air duct: new
    F.I. lines: cleaned or changed (2), plated
    ...and many but many other small things.
    So, how much do you think the work cost? The final price is in Euro and with 22% VAT included
    ciao
  2. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    €40k
    Am I even close? :)
  3. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,328
    Montana
    Kim
    52 Euro including VAT?
  4. gt4me
    gt4me F1 Veteran
    Sep 10, 2005
    5,671
    Lewis Mitchell
    28k euro.
  5. Albert-LP
    Sep 1, 2010
    8,177
    Alberto Mantovani
    let me know your mechanic and next time I will ship the car there... ;)
    #106769: Differential £4,537.70 Each means 5000 euro + VAT = 6000+ euro (from Eurospares site)
    The SS Tubi Muffler is 2400 euro.
    And I forgot to write all 8 pistons and an ignition coil in the work list
  6. Albert-LP
    Sep 1, 2010
    8,177
    Alberto Mantovani
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    70-80k euro?
  8. 4right
    4right F1 Rookie Rossa Subscribed
    Sep 14, 2008
    2,966
    US/Japan/Singapore/Canada/US
    Agreed, You and I are in the minority so far though.
  9. Albert-LP
    Sep 1, 2010
    8,177
    Alberto Mantovani
    I forgot: fuel injectors (new), Airbox red painting, all the filters, engine cleaning, some bearings here and there in the engine, all four new wheel bearings, rear lights polishing, mirrors wirings, new passing lights (new OEM Cibie), new radiator fan switch. new fuel tanks venting tubes, new fuel tanks filling hose and several other details like that. No single piece of the car mechanic has been passed over: every single one has been tested, fixed, painted, plated or changed with a new one. I was scared when I went there yesterday, fearing a 100 k bill... I'm not rich, just a big enthusiast and no more.
    I really wanted a like new car, as this fu@ky 208 GTB turbo was introduced when I was 20, in 1982, and was my youth dream: this time I closed my eyes without considering the car reselling value and went for the top restore possible. Who cares of the cost, I told myself: but yesterday I wasn't relaxed at all when the mechanic read me the never ending list of the works done...
    Once I purchased a bad Countach that I fixed everywhere, but this one has been restored with even much more care, pieces and details. I'm very proud of it: I hope it will work, after so much money and time... ;)
    ciao
  10. brian.s
    brian.s F1 Rookie Professional Ferrari Technician
    Nov 3, 2003
    3,809
    Midwest
    Brian
    If the rest matches the engine work, I am very impressed by his standards.
    Cost? upwards of 100 Euro
  11. 308 milano
    Jan 15, 2007
    5,328
    Montana
    Kim
    Been thinking about this all morning.. Going to revise my number and agree with Crowndog and 4Right, 70-80k Euro. No way is that going to come in at 52k. Very nice BTW! :)
  12. Albert-LP
    Sep 1, 2010
    8,177
    Alberto Mantovani
    Yes, it matches. It's a world wide famous Italian shop. All what they did is in that standard, of course: same quality they use for the 250 LM and others much more expensive Ferrari. It's a Ferrari only shop.
    I have to say that they told me it's the first time ever they do such a restore on a "poor" 208 turbo.
    ciao
  13. qedqeq
    qedqeq Formula Junior
    Apr 15, 2015
    384
    LOLOL
  14. MS250
    MS250 Two Time F1 World Champ Lifetime Rossa
    Dec 10, 2003
    26,580
    Avvocato
    I have my popcorn popping
  15. AaronMeisner
    AaronMeisner Formula Junior
    Jul 15, 2014
    267
    Baltimore MD USA
    Aaron Meisner
    So glad I picked up a used long block for under $4k a year ago!
  16. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    I'm sure you have the best 208 turbo in the world now. Congrats!
  17. bundas
    bundas F1 Veteran Owner
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    $259,000 + and two years
  18. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Priceless:)
  19. Jdubbya
    Jdubbya The $10 Trillion Man Silver Subscribed
    Dec 28, 2003
    43,251
    PNW
    I will admit to being one of the dolts who voted for less than 20K. I didn't read the entire list and you have added some really spendy bits after the original post too. I also didn't see the bit about 22% Tax :eek:
    So my new guess would be 50K-60k with the tax. I'd guess the base bill came in somewhere north of 40K
  20. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    E208k ��
  21. jimgolf1
    jimgolf1 Formula Junior
    Aug 23, 2013
    375
    Reno, NV
    Jim Small
    Knowing what I spent on my car with no major engine or paint work I'm going to guess $87k euros. If you had to do paint and bodywork I would say closer to $150k euro.
  22. Albert-LP
    Sep 1, 2010
    8,177
    Alberto Mantovani
    They did just the mechanic, no interiors and no exterior body work: The car was already fully restored in the body by the previous owner. My mechanic just painted the suspensions, wheel arches, engine bay, fuel tanks, front bay, airbox.
    I did all the leather cream interiors and the steering wheel but there I paid another specialist: The cost is just for the full mechanic restore.
    I'm sure that such a mech restore done in the USA would cost over 80 k USD (and without taxes)
    Ciao
  23. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    My new guess is €65k consider the new added list and the 22% vat that I missed previously :D
    22%! Gosh...
  24. Andy 308GTB
    Andy 308GTB F1 Rookie Lifetime Rossa
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    You certainly won't be after you have paid your mechanic :D
    All in, I would agree with the EUR 80k figure
    If you gave the garage a clear brief at the beginning of the project you may have done yourself a favour as the economies of scale would have helped. i.e. one large batch of part s to be plated, one batch of suspension parts to be painted etc.
  25. Albert-LP
    Sep 1, 2010
    8,177
    Alberto Mantovani
    the (almost) complete list of work done:
    Valves: new (all)
    pistons with pins and rings: new (all)
    cilynder slivers: bored
    crankcase: machined the crankshaft bearing housings
    crankshaft bearings, rods and crankcase bearings: new (all)
    camshafts: polished
    clutch: new
    diff: new
    waterpump: new
    A/C compressor: new
    brake pump: new
    steering rack: new
    fuel lines: new
    fuel pump: new
    engine mounts: new
    water nourice: new
    fuse boxes: new
    fuel injectors: new
    Airbox: painted
    air filter: new
    fuel filter: new
    wheel bearings: new
    radiator fan switch: new
    fuel tanks filling hose: new
    fuel tanks venting tubes: new
    and then engine cleaning, some bearings here and there in the engine, rear lights polishing, mirrors wirings, new passing lights (new OEM Cibie) and many but many other small things.
    All that to say that a "don't skip anything" restore is very expensive. Consider that it was a car with 129500 km (more or less 81000 miles). Everything was destroyed after 81000 miles and 33 years, even the front springs... Yes this is the first turbo (with an already rebuilt turbocharger, fortunately), so the engine had more problem than a carbed 308, but a carbed 308 with 129000 km doesn't require much less too...
    So, be careful when you buy a very old car with many miles, as this is what you get: a car that needs help and fixing in almost every piece. A VERY expensive fixing, as a car is made by thousands of pieces: I learned that when I almost died while hearing all that endless list of pieces changed or fixed or painted and plated...
    So, how much did it cost?
    I have to say two things in advance:
    1) here around Modena there are big specialists that can fix those cars also when blindfolded and know how to find pieces at a lower cost (for example 3x8 belt tensioners are the same of Fiat Ducato ones and so on) and they (sometimes) know how to find NLA pieces at a fair price. Not all are cheap and really experts also here, but as average (I suppose that) they are much cheaper than an USA specialist, for example (this is just my idea, sorry 2NA).
    2) My mechanic told me in advance there would have been a very special price for this one, as it was the tenth car in two years that I sent there to have a major service or a restore. So the (very long) labor cost was very low for a Ferrari famous specialist and the prices of the spare parts are the lowest possible, just to gain something.
    Well, at the end I think I saved 20 k euro due to the superspecial price my mechanic gave me for this huge work (that is the biggest they did on a 208 ever).
    So the final price is exactly 20 k less than the expected 62 k euro cost (here in Italy, taxes included) and the 70 K USD (without any tax) I think you should pay in the USA.
    This price doesn't include interiors, tools, a manual, new TRX tires and some small other things for the body, the body polishing and some body details.
    Well, I paid the car 48 k euro: a very good price for a 208 GTB turbo with a perfect body paint, Modena black plate and special option leather interior with red wire, perfect rims paint. Despite this very fair price for the car's restore, the car final cost is 98 k euro (YES!!!): I think it's the most expensive 208 GTB turbo in the world.
    Please don't try to repeat this disaster... ;)
    ciao
