How much oil do I put in the clutch gear section? | FerrariChat
Discussion in '308/328' started by qedqeq, May 5, 2017.
  1. qedqeq
    qedqeq Formula Junior
    Apr 15, 2015
    384
    #1 qedqeq, May 5, 2017
    Hey all
    My workshop manual says that I need to add 100gr.of oil into the clutch gear section
    How much is 100gr.of oil? Should I weigh the oil before it goes in?
    I always put in what I took out, I would say about close to 1 liter.
    Why doesn't it just say the volume, like all the rest, instead of the weight?
    Maybe it's 100grains, instead 100grams, like my hogdgon H1000 for my 338-378 Weatherby Magnum cartridges, LOLOL
    Regards
  2. Rifledriver
    37,122
    Any excess will flow into the transmission.
  3. qedqeq
    Apr 15, 2015
    384
    Really?
    Maybe I should just fill the gearbox from there instead? Until it flows from the drain plug in the gearbox
    Regards
  4. Rifledriver
    37,122
    The drain plug? I really hope you mean the fill plug.
    If you have all day. It takes forever to fill it there.
  5. qedqeq
    Apr 15, 2015
    384
    OOOPPPPSSSS
    That's what I meant, LOLOL
    Thanks for this, learned something new today
    Regards
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    It takes a while but if you don't have a ramp/lift & the means to get the oil into the side of the box, its a very easy way to do it. Long funnel or a piece of hose & a funnel & 4 1/4 bottles of Redline usually does the job......:)
  7. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    391
    Herts, UK
    Richard
    Spot on what I do.
