How much power is lost in the drivetrain ? | FerrariChat
Discussion in 'Technical Q&A' started by t024484, Nov 28, 2007.
  1. t024484
    t024484 Karting
    Nov 9, 2006
    171
    Netherlands
    Hans A. Polak
    My 456M GT was put on the dyno this week, see the 456 forum.
    Much to my surprise, the losses at max power were only 7% (31Hp@5500rpm).
    I find it a bit hard to believe that the drivetrain losses are so low.
    Figures that I see in other tests are between 15 and 25%.
    I would expect that when you put 450Hp on the drivetrain, that the losses are substatialy higher than when the decoupled drivetrain is propelled through the rearwheels from the low power Dyno.
    In someway, the drivetrain losses must be related to the power involved. The more power, the more friction, the higher the losses.
    The measurement from the Dyno on the other hand will always measure the same losses, independent of the engine.
    Does anybody has some experience in this area ?
  2. PAP 348
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    Wow!! Could this be that the 456 driveline is so efficient Han's? :):)
    RWD cars usuall suck up around 30% drivetrain loss. My 348 was put on the dyno over a year ago and I recall around 10-15% drivetrain loss. :):)
    7% is really good, if it has been calculated correctly by the dyno. :):)
    Thanks for sharing mate, very interesting stuff. :):)
  3. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,424
    Alabama (was Mich.)
    Jeff
    This stuff always fascinates me....I'm in agreement that "average" power losses are 15% to about 25% or so. I don't think it's possible to have a loss of only 7%. This does bring up a BASIC question:
    HOW are they determining the power loss? Are they comparing the MEASURED power against the FACTORY RATED power?
  4. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,843
    Atlanta
    John!
    I believe drivetrain power loss to be linear and not an even number all across the rpm range. With how high Ferrari engines spin, I imagine the power loss in the drivetrain to be substantial at high rpms (different with each model obviously). An article was written in a hot rod magazine a few years ago, and I recall it being named, "the Horrible truth" or something to that effect.
    The purpose of this article was to determine exact drivetrain loss for this particular manual transmission '60s Ford drivetrain. The engine flywheel dyno'd at 355bhp or so. I cannot recall the exact figures, but the engine was reinstalled and then dyno'd at the rear wheels and loss an enormous 27-28% at the rear wheels. Peak power was made just over 5kRPM.
    I would think F* engines would have severe drivetrain penalties as well considering how high they produce their peak power.
  5. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I actually believe its just the opposite. That you start out with high drag, high HP loss, and it begins to flatline as power goes up. But there really isnt a lot of data out there thats readily available.
    I will say though that I find a 7% loss at the wheels almost impossible.
  6. t024484
    t024484 Karting
    Nov 9, 2006
    171
    Netherlands
    Hans A. Polak
    Determining power losses on a Dyno is really quite simple.
    With the gearbox engaged, and the clutch pressed down, the Dyno propels the rearwheels at various speeds and simply measures at the same time how much power is needed to do this.
  7. DGS
    DGS Seven Time F1 World Champ
    71,700
    MidTN
    DGS
    AWDs are notorious for horrendous drivetrain losses.
    But for a comparison, google for an "EVO MIEV" -- a "Mitsubishi In-wheel Electric Vehicle". Mitsu took an EVO IX and removed the engine and drivetrain, and installed four electric motors inside the wheels.
    Four 50 Kw electric motors total only 6 Kw less than the gas powered (JDM) EVO, and with 518 Nm at each wheel, the electric adds up to an insane amount of torque (compared to 355 Nm total on the gas engine). It only weighs about 100kg more than a standard EVO, too.
    And no drivetrain losses.
    So why is the electric almost 2 sec slower to 100kph than the gas car, despite all the AWD power losses in the gas machine?
    I'd say it's the unsprung mass. The gas car can put all 206 Kw (minus all those drivetrain losses) to a single wheel, if need be. The electric tops off at 50Kw per wheel, so any wheel not nailed down subtracts from the total power. And with all that mass in the wheels, when it comes unstuck, it's not coming back any time soon. (I'd guess it's a gold-plated b**ch to drive at the limits.)
    Neat concept, though. But an interesting comparison as to what we get for all those drivetrain losses.
  8. t024484
    t024484 Karting
    Nov 9, 2006
    171
    Netherlands
    Hans A. Polak
    I believe that your question is simple to answer. An electric motor has lots of torque when starting, and the faster it goes the lesser torque it has.
    A petrol engine comes relatively fast to 70% of its maximum torque and has an ever increasing torque until high revs.
    Power is torque times revolutions. So the petrol engine has much more power at higher revs, where most of the acceleration takes place.
  9. DMOORE
    DMOORE Formula 3
    Aug 23, 2005
    1,720
    San Diego
    Darrell
    Large mining trucks have used this system for years. Obviously on a MUCH larger scale.
    Darrell.
  10. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    You shouldn't post drivetrainloss in %. F.e. a drivetrain rwd for arround 250-400hp / 500nm has a loss of ~30-40hp at 7500rpm. Drivetrainloss depends on the rpm and for wich performance they are made. The drivetrainloss comes from the friction of the material because that it is a exponential curve over the rpm band, it has nothing to do with the engine power output. You can't say the 100hp engine has a drivetrainlos of 10% 10hp. Because it would have 10hp on 7000rpm but 20hp loss on 8000rpm and 5hp on 4000rpm. And if you mod that engine to 200hp it would have still 10hp on 7000rpm and not 20hp.
