How much power out of a 348 engine? | FerrariChat
Discussion in 'Technical Q&A' started by zsnnf, Nov 22, 2004.
  1. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    How much power can you get out of a stock 348 bottom end? I am mainly concerned about the stock block and crank. Does anyone have examples of supercharged or turbo'ed motors making over 500HP with these parts?
    Rick
  2. Rifledriver
    37,288
    The F40's have the same bottom end. Due to the turbocharging they have a system to cool the pistons with oil jets. The stroke of the crank is different and I would bet that the rod length is different as well but the quality and strength of the parts is the same.
  3. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    my 348 turbo makes just shy of 500hp (498 calculated)
  4. tbakowsky
    Sep 18, 2002
    20,034
    The Cold North
    Tom
    I thought the bottom end in the F40 was that of the 328..but with higher quality components. The pictures in the F40 engine rebulid thread seem to confrim this, by the casting of the block. The 348 block has a much much different in casting. But please correct if I'm wrong...
  5. Rifledriver
    37,288
    You are correct that the block is essentially a 328 but as far as the structure of the crankshaft support etc the 348 is the same. From my experience the quality of components in the 328, 348, 288, F40 are the same. It speaks very well for the strength of the basic V8 motors. The only real problem I have seen in the bottom ends of the turbocharged ones is that they stretch out the main webs making them oval. You have to get creative to put everything right and keep the crankshaft centerline in place to prevent problems with the drive gears.
    A girdle like the 430 is reported to have would really be the ticket.
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Koenig has a twin turbo setup that makes 520hp. They do change the pistons, to ones suited for turbo charging. More than likely a lower compression ratio. As for the con rods and crank, I don't think they mess with those.
