How to Remove Outer Door Panel and Replace Door Handle on 355 | FerrariChat
Discussion in '348/355' started by bcb70, Jan 11, 2014.
  1. bcb70
    bcb70 Karting
    159
    Northern VA
    Brian B
    #1 bcb70, Jan 11, 2014
    After owning my 355 for a few months the drivers side door handle broke. I saw several posts about this but none detailing how to do it yourself. So here it goes:
    Tools needed:
    4mm hex key (allen wrench)
    10mm wrench or socket
    pencil
    First to change the door handle it is necessary to remove the outer door panel.
    1. Open the door. There are 2 10mm nuts on the under side of the door. Take a pencil and trace around the washer/nut. Loosen, don't remove the nuts. When you replace the panel you want to line these up. This aligns the panel with the body lines.
    2. With the 4mm hex key remove the 2 bolts under the air intake where the door handle is. One bolt located in the center of the panel and the second is the inboard bolt of the door handle. The bolt to the rear of the handle will be removed once the panel is removed.
    3. In the door jam there are 2 10mm nuts. Remove these but be careful of the washers used as spacers. Try not to let them fall.
    4. Gently wiggle the panel loose
    5. Now remove the rear bolt of the door handle and remove handle. If your handle was broken try to find the broken piece inside the door. You'll need the threaded bumper piece from the broken part.
    6. I would suggest ordering the replacement part from Ricambi. It's a nice piece of machined aluminum and will last forever.
    7. On the door handle remove the small locking pin. A small nail can be used to push the pin through.
    8. Push the rod through the handle assembly far enough to get out the broken piece.
    9. Remove the broken piece and insert the new part, be sure to insert the spring end into the hole of the new part.
    10. This takes a little talent - push the rod through the aligned hole of the new part and door handle (this might take a few tries). Replace the locking pin. With the new part installed on the handle install the threaded bumper into the new part.
    11. Place the handle into the door. This took me a few times to get it right. Once I was able to ensure the piece fit properly I removed it and applied white grease to all moving parts.
    12. Install the rear bolt of the door handle.
    13. Gently place the door panel back on the door. Fit the tabs under the loosened nuts on the bottom.
    14. Install the remaining two bolts under the air intake. Do not tighten yet.
    15. Install the two nuts in the door jam. Be careful of the spacer washers. Snug but don't tighten.
    16. Now, align the washer/nut on the bottom of the door with your pencil marks. Tighten down the nuts.
    17. tighten the remaining bolts and nuts. Double check the door handle is functioning.
    18. Gently close the door incase something isn't aligned.
    19. Hopefully everything is functioning and aligned.
    It's a simple process. I did it in about 1.5 hours in my condo parking garage.
    Feel free to contact me if you have any questions.
  2. bcb70
    bcb70 Karting
    159
    Northern VA
    Brian B
    Can anyone tell me how to link this thread to the 355 Do It Yourself thread?
    i can work on the car but can't figure this computer stuff out :)
  3. bcb70
    bcb70 Karting
    159
    Northern VA
    Brian B
    Thanks Dave. You rock!
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
  5. hallsdad
    hallsdad Karting
    Mar 6, 2010
    88
    Cayce, SC
    Steve
    Just wanted to say thank you for posting this fix. This happened to me this afternoon and will be my first Ferrari fix since ownership.
  6. Ferrari Fanatic
    Ferrari Fanatic Formula 3
    Apr 2, 2003
    1,317
    SoCal
    Thank You for posting. The DYI was posted just in time. My door handle broke just this week.
    Super easy to replace with these instructions.
    Only thing I would add is get some Locktite as the original allen bolts were Locktited with Red High Strength.
  7. TinkerF355
    TinkerF355 Rookie
    Jul 10, 2022
    10
    France
    Thank you for this, easy to take off, a pin in the proverbial to put back.
    Ensure the cage clips are aligned before putting everything pack together.
  8. cyberias
    cyberias Rookie
    Feb 26, 2021
    1
    Finland
    Kimmo Jokinen
    Thanks so much for posting these instructions. I just today installed new rear grill gasket for the LH (driver) door, and when testing the gasket alignment, the door handle bracket broke! After fitting the gasket, the door opening obviously required a bit more force - and snap.
    I look at the bright side: it was good that the handle broke during winter break, and not during next summer drive to the Alps... :)
