How should I increase front end down force on my 348? | Page 2 | FerrariChat
Discussion in '348/355' started by angelis, Dec 10, 2012.
  1. jqpd99
    jqpd99 F1 Rookie
    2,523
    Ottawa
    DFO
    Any close-up pics of your splitter?
    DF
  2. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    #27 marcov, Dec 13, 2012
    FloridaIsland348 likes this.
  3. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Very nice.
    Did you notice any difference afterwards?
  4. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    It is hard to tell, I think there is a slight stability improvment, mostly the front does not feel as light.
    I thinks it looks good, the only problem are speed bumps and uneven roads.
    I plan to paint the carbon fiber black to match the lower bumper in the spring.
  5. brent Lachelt
    brent Lachelt Formula 3
    Dec 6, 2003
    1,831
    Brownsburg, INDIANA
    Brent R.Lachelt
    That actually looks really nice:)
  6. mdsassaman
    mdsassaman Karting
    Nov 4, 2006
    246
    Reading, PA
    Mike Sassaman
    I'll take some close-up pics tonight if you want to see them.
    Reading, PA
  7. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    #32 jm3, Dec 14, 2012
  8. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    think I'm going to be sick
  9. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,460
    On the Limit
    Dino
    I had one of the first 348s, and the high speed handing was diabolical above 150mph. The low speed handling was a bit 'tricky' as well.
    The addition of the Serie Speciale front spoiler, wider rear track and 18" Challenge wheels changed everything from bad to brilliant!
  10. mdsassaman
    mdsassaman Karting
    Nov 4, 2006
    246
    Reading, PA
    Mike Sassaman
    #35 mdsassaman, Dec 16, 2012
    Here are a few pictures of my splitter. I have a sheet of the material 1/2" thick "Starboard" and it has a texture pattern on the top side. I have the pattern for the 348 from the one that the PO had on my car. It sticks out 1" from the fiberglass to where the rounded edge begins so in other words it sticks out in the front about 1 1/2" total. It does lower the front end by 1/2" but when it scrapes there is no damage to the fiberglass and the HDPE splitter will last for years. It is black in color. If anyone wants one let me know.
  11. jqpd99
    jqpd99 F1 Rookie
    2,523
    Ottawa
    DFO
    I may be... check yer PMs
    DF
  12. Armenhaz
    Armenhaz Karting
    Nov 8, 2005
    232
    Glendale, CA
    Armen
    Did you have issues with your car before, like front end wondering at speeds above 80 mph? And what did you notice in the cars handling at speed after you put your splitter?
  13. mdsassaman
    mdsassaman Karting
    Nov 4, 2006
    246
    Reading, PA
    Mike Sassaman
    I never felt any handling issues in my 348 but maybe it is because I always had this splitter on the car, my car is an SS with the wider rear track, my car has 360 wheels and tires on it, etc. The previous owner had the splitter installed on the car and I just replaced the same thing with a new piece of HDPE material. I kept the old one as a pattern and have made and sold about 4 of them to FChat friends so far. When I switch back to the original wheels and old tires I do feel a wandering but I attribute that to the old tires that are not in such good shape. I only put these wheels and tires on for Concours events judging and don't drive very far or fast. Someday I'll replace those tires too.
  14. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Even without the splitter the car shouldn't "wander".
    I had a similar "floating" experience when I first got the car. I then took it to have it four corner balanced, right hide adjusted and it was an instant improvement. I track the car frequently and exceed 100mph on the straights easily and there is little to no float.
    I did order this splitter just to see if I do get more "bite", and it looks pretty cool... :)
    Get your car adjusted first is my recommendation.
    Kai
  15. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    I had two full beer cooler in the trunk one time, that worked pretty good
  16. Kaivball
    Jan 11, 2007
    35,997
    Kalifornia
    Got the splitter.
    Looks very solid overall. I will suggest that you should get a better straight edge... :)
    I'll have to machine it slightly to make it straight. There is some visible waving in the cut. More on the inside (where it thankfully doesn't matter so much) but some on the outside lip as well.
    Overall, it'll do a much better job of absorbing any bottoming out of the front spoiler instead of taking it directly onto the fiberglass I think.
    Kai
  17. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Well.... haven't managed to do anything yet as the 348 has been stuck in my garage due to the garage door motor breaking.
    Will be going to the paint shop in the next few weeks for some minor rectification work and to have a short race splitter and challenge light covers added.
    Still trying to source a decent rear spoiler.
    Once the paint work is done, it will be used for filming the "Worst Ferrari Ever made" documentary feature in Spring before having a wrap applied to it.
  18. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Splitter, wing and cannards ordered
  19. fatbillybob
    Aug 10, 2002
    29,359
    socal
    You should then consider lightening up the car and upping the spring rates or adding horsepower and upping the spring rates.
  20. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    I've got an adjustable Quantum Racing suspension system already installed.
    Car is at 1400kg now. Don't want to start ripping things out as I still want it to be semi comfortable.
    Last mod will be the engine which I will do next winter. Going to do what Andy's done to his with big trumpets.
    After that, I'm definetly finished with modding it.
    Got a pic of the spoiler which we stuck on the car today. Can't upload pic from iPhone so will upload tomorrow.
  21. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
  22. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
  23. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
