How this happen? Hawker nose wheel stuck sideways! | FerrariChat
Discussion in 'Aviation Chat' started by energy88, Oct 16, 2019.
  1. energy88
    energy88 Three Time F1 World Champ
    32,169
    West of Fredericksburg, VA
    A private aircraft was forced to make an emergency landing at Richmond International Airport on Wednesday morning due to issues with a “sideways” nose gear.
    The Richmond International Airport (RIC) in Virginia confirmed the plane’s crew declared an emergency shortly before 8:30 a.m., citing trouble with the landing gear. Upon landing, the airport wrote on Twitter that the “sideways” nose gear forced the aircraft to “veer” off the runway and into a section of grass.
    https://www.foxnews.com/travel/plane-emergency-landing-virginia-airport
  2. jcurry
    24,071
    In the past
    Jim
    they knew something was wrong since they declared an emergency prior to landing.
    broken or damaged link in the steering system
    some description of the NG system can be found here
    http://www.smartcockpit.com/docs/Hawker_00XPC-Landing_Gear.pdf
    One scenario is that the aircraft was towed prior to departure and the ground crew did not remove the steering disconnect pin. When they towed it the pin sheared which would then disable the NG steering. They could still have taxied using differential braking and not considered why the normal steering was not functioning properly.
    energy88 likes this.
  3. kylec
    kylec F1 Rookie
    3,670
    Orlando
    It happened to a JetBlue Airbus around 2010
  4. Flash G
    Flash G Three Time F1 World Champ
    36,567
    Hollywood Hills
    Christopher
  5. SAT4RE
    SAT4RE Formula Junior
    Dec 5, 2003
    595
    Blairsville, GA
    I landed in Richmond earlier this evening. Talked to the ops manager who showed me photos from the incident. He said the Hawker veered right after touchdown, shot across one ditch, went airborne momentarily, and then ran through another ditch. The left wingtip dug in to the ground at one point, and the rear of the plane was nearly sitting on the ground once it stopped. They were able to tow it to a hangar.
  6. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Several aircraft are engineered such that their nosewheels are steered by a single actuator that pulls the wheel to center position opposite a "sprung" side. Failure of the actuator causes a "hardover" condition where the wheel is stuck in the sprung direction. Crazy design but simple...until it fails. Harrier has a nosewheel set up like that, and I watched one rollover upside down on landing after the wheel failed on rollout. Even crazier...the Northrop T-38 has the rudder set up in a similar fashion which can lead to "rudder hardover" which is a bear...
  7. energy88
    32,169
    Wonder who was the inventor of that design?
  8. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
  9. tazandjan
    39,163
    Early 737s had the same hard over rudder problem.
