How to adjust a 328 window? | FerrariChat
Discussion in 'Technical Q&A' started by GrigioGuy, Aug 13, 2005.
  1. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,425
    E ' ' '/ F
    Enzo Gorlomi
    I replaced a lift mechanism in my 328. Everything's back together correctly, but the window has a gap of about an inch at the top. I took the motor out and ran the window up with a rachet, so I know the motor isn't the issue.
    I simply cannot find any adjustments for the window location. Anyone worked on one of these?
    t
  2. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    My 77 308 had a simple sliding "bolt - in - a - track" adjustment. Towards the rear of the door. The bolt is attached to a pulley, which will control cable length....
    Greg
  3. GrigioGuy
    Nov 26, 2001
    33,425
    E ' ' '/ F
    Enzo Gorlomi
    Thanks Greg, but no pullies or cables on a 328.
    I'm comparing the old and new lifts, and it seems that I'm a victim of Italian quality control -- the new piece just doesn't lift as high. Going to have to modify it a bit to clear an obstruction.
