355 - How to adjust alternator belt tension | FerrariChat
355 How to adjust alternator belt tension
Discussion in '348/355' started by F355Bob, Jul 4, 2019.
  1. F355Bob
    F355Bob Formula 3
    I changed my alternator . How do you determine belt tightness?
  2. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    I always made mine to give less than say a finger.
    Be careful with that adjuster. Leave the main bolt on the pulley a little loose until you get the belt how you want it. Trust me on this...
    But if you don't, I have two perfectly welded alternator brackets I'll sell ya cheap. [emoji6]
    I may have bought the last two OEM ones in the world. Lol
    Sent from my SM-G965U using Tapatalk
  3. F355Bob
    F355Bob Formula 3
    Where are you checking tension. One longest span from water pump to crank pulley or from tensioner to alternator
  4. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,014
    NE FL
    Ken
    My mind defaults to thoughts of bearing wear belts are to tight.
    Since this is more of a non critical belt, I set mine up loose and of course, it squeaked. so I tightened it a little and all is well.
    I would say the deflection is a finger or two on the longest belt span.
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Gates clicker tension deal works great and dead on, I have a full set and a harmonic tension meter, yeah Im a belt tension gook LOL
  6. F355Bob
    F355Bob Formula 3
    Are you using it with engine in?
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Yuup easy
    WATSON and MAD828 like this.
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Thanks to Tim this is what I used and its dead on. Checked it 2 ways and they were all very close.
    You need two if you want to do alternator and water pump because of the range and span I believe.
    SoCal1 likes this.
  9. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,013
    PA
    Kevin
    Does anyone have the factory spec for AC compressor belt tension? My digital WSM states this is on page I-36 but I do not have that page.
  10. F355Bob
    F355Bob Formula 3
    Ordered the gauge and will get tomorrow. Where on the belt are you measuring? Between water pump and crank pulley or alternator to water pump? Reaching from underneath car? Happen to know how many pounds of tension?
    WATSON likes this.
  11. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    Good luck reaching up from under the car to get to the long section of the belt ;)
    Mate, i think you are over thinking this belt thing. I have never used a device for testing the aux belt in 15 years of working on 355s.
    kenneyd likes this.
  12. WATSON
    23,679
    WI
    Well, if you can't measure it, you can't manage it.
    Bob: Which one did you order?
  13. F355Bob
    F355Bob Formula 3
    I got both. The Dayco klicit as in the video. Was $25 for both. No room to measure the longest span with it in the car. You can't get your arm up there so will just wing it and make sure more loose than to tight.
    WATSON likes this.
  14. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Longest span I believe... but i haven't been under the car for that awhile. Going on my newly old man memory.
  15. F355Bob
    F355Bob Formula 3
    Yeah longest span and not more than 120lbs which is pretty tight.
  16. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    #16 Jackie and bill, Jul 11, 2019
    Well if you cant get to it, you cant measure it or manage it now can you. :rolleyes:
    Why not advice bob on how to do the impossible and get the the side of the belt. I am.willing to learn this technique.
  17. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    As i was saying, you cant get to the belt with the engine in.
    It makes me wonder if certain people on this thread have acualy done the job, i call BS on any one who claims they can get to the side of the belt to use any device.
    As i said mate, dont over think it.
  18. m.stojanovic
    m.stojanovic F1 Rookie
    3,213
    Serbia - Niš
    Miroljub Stojanovic
    Challenge and WATSON like this.
  19. F355Bob
    F355Bob Formula 3
    You're right. No way to use these gauges in the car. You might be able to measure the a/c belt but not the alternator belt. No room.
  20. F355Bob
    F355Bob Formula 3
    Adjusted belt . Was too loose and squealing so tightened a little and now ok. I notice on start my battery light on for 6 seconds and then goes off. Is that normal? Don't know that I remember that before.
  21. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    If there was a problem your light would stay on. It should go out straight after start up. If it goes out after a short time then its charging ok.
    Assuming your battery has a full charge, i say take it for a run and see what it does, if it stays on then there is a charging problem.
    You have made sure your conectors are all secure at the rear of the alternator? Also check that you have connected the earth strap if one was fitted. Some owners have added one.
    Please let us know your findings.
  22. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Did you rebuild or replace your alternator? I assume that was the reason for its removal in the first place.
  23. F355Bob
    F355Bob Formula 3
    Replaced with a new alternator . Everything is tight and there is a factory ground strap. Will take it out in a little while
  24. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Good, I think it will be good mate. Please let us know :)
  25. F355Bob
    F355Bob Formula 3
    Took it out and was fine . No battery light came on duri g driving. Image Unavailable, Please Login Here is gauge im putting in to replace the clock so I'll know if it is charging. Thanks for the help
