How to avoid cooking F40 rear bumper ? | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by WILLIAM H, Jan 25, 2009.
  1. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    So I drove down from PM to Miami today. When I got home the rubbery black part od the rear bumper was pretty much cooked
    I have tubi straight pipes on it
    should I wrap the exhaust or add extensions ?
    How do I keep it from getting toasted again ?
  2. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    The best way to avoid it, is to do what most F40 owners do... trailer. ;)
    1st question... do you still have the cats?
  3. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    Wouldn't the cats run hotter than straight pipes on the F40?
  4. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    I've got straight pipes no cats on mine too. I'm guessing you have no cats otherwise your car is running waaay too rich. If you look at various pics, you will see some have their pipes inset, or flush with the bumper. That is a problem. You want them to stick out about 1 -2" iirc; I dont have mine in the garage at the moment or I would measure them. But they should stick out a bit. I've also seen picks where ppl use metal tape on the bumper, works but looks meh
  5. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    #5 frefan, Jan 25, 2009
  6. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    #6 frefan, Jan 25, 2009
  7. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Take the cats off. Running cats on an F40 is a BAD idea. Like literally harmful for the car. It will run better, cooler, safe and more reliably w/o cats. No joke.
  8. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Pictures?
    Cooked as in "sooty", "crispy" or all the way melted?
  9. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    #9 WILLIAM H, Jan 25, 2009
    The black rubbery paint above the exhaust is Gone, the part underneath is ok, the area just N of the exhaust is a little burnt
    my exhaust tips are flush w the exit, I will have them wrapped and extended a little
    Trailering is for pole smokers
  10. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    #10 frefan, Jan 25, 2009
  11. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    #11 joe sackey, Jan 26, 2009
    Completely misunderstood. Especially as the title of this thread referenced "BUMPER"!
    What you are speaking of is the paint peeling off the oval bezel that surrounds the exhaust tips aperture. The paint flakes off the bezel on almost any F40 that is driven, and the more you drive it, the more it flakes.
    BTW, even with Tubi pipes and no cats, the setting of the Tubi pipes and replacement by-pass cones which your car has - Ive seen it personally - allows extrusion of the tips by 1". However, the rear valance has a certain amount of play that is possible in setting it up upon remounting if it has been off (often not properly aligned - much discussed on the USA F40 thread, and illustrated below) and thats a possible source of the tips sitting flush with the rear panel of the valance. It may simply need to be snugged up forwards. You'll notice this when closing the rear hood and the lynch pins are not exactly aligned. I would check that before doing anything with the exhaust unit. Of course the upper hood goes out of whack also and can be adjusted - I know, we did this with one of my F40s and the net result was the bottom image...
    Also, if its just the bezel thats getting toasted, well, thats what its there for, and I personally wouldn't even bother wrapping the pipes as that always looks a bit boy-racer naff IMO.
  12. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    I like the white coated look, very race-car / vintage ferrari inspired.
  13. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    I'll post some pics, I guess my car is running rich as the exhaust is very black,
    its not just the bezel, the paint bubbled above the bezel and well the photo will show it better
  14. nopassn
    nopassn Formula 3
    Nov 19, 2003
    1,959
    Kansas City
    Roy
    I actually LOL'ed when I read that. That's awesome.
  15. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #15 Napolis, Jan 26, 2009
    Rich is soot but lean is heat. Is the bumper sooty or burnt? First I'd get a tune. Next I'd ceramic coat the entire exhaust which will keep heat in the exhaust gases but the pipes themselves will stay much cooler . Car will run better and make more HP. Next I'd shield carbon near the pipes with cool mat and the area that the pipes exit with titanium and any area that the exhaust gas touches with titanium.
    Ceramic coatings come in any color including polished stainless look.
    We found this worked well for us.
  16. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    or you could just get a p4/5 ;) that should fix it
  17. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Bit harder that. I'd stick with a tune/cool mat/ Ceramic coating and a Titanium pass through.
  18. AustinMartin
    AustinMartin F1 Veteran
    Mar 1, 2008
    5,445
    Los Angeles/Idaho
    So I've heard... :D:D:D
  19. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    I've seen more then one F40 when that little black piece seemed to be replaced by a stainless steel looking one. Looked good.
  20. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    You could also ceramic coat the surround black.
  21. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    #21 WILLIAM H, Jan 26, 2009
  22. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Flames.
  23. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Yeah, I read here the price is tanking!
    Should get it for $17.95 by april 1st.
  24. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #24 Napolis, Jan 27, 2009
    Likely less.
    Bill
    IMO you're running way rich. I'd start there. Running Rich can also cause undetonated fuel to burn in exhaust system which can result in unpleasant things. If you were too lean the inside of the pipes would be grey/white. I'd also check out Mike's suggestion. You of all people should know extra length is always good. Either way car will make more HP with Ceramic coating which you unlike some will actually use. (Pulling them on and off trailers doesn't require too much HP)
    Sorry I missed your little one. Great to see you. Save a Glock for me.
    Best
  25. sailquik
    sailquik Formula 3
    Feb 27, 2006
    1,645
    In a temperate zone
    Charlie
    +1 Funny stuff.
