How to change gearbox oil in a 308?? | FerrariChat
Discussion in 'Technical Q&A' started by SlickMurphy, May 6, 2005.
  1. SlickMurphy
    SlickMurphy Formula Junior
    Aug 18, 2004
    275
    Essex
    David
    I have done many searches on how to change my gearbox oil in a 77' 308 and have found nothing. Does anyone have a link to a thread or some advice for my local mechanic on how to do this. And since I have your attention, how do I change the brake fluid and can you suggest any good brake fluids?
    Thanks as always,
    David
    PS- Where can I buy Redline 75W-90 NS online?
  2. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    If your local mechanic can't figure out how to do gearbox oil on a 308, time to find another mechanic.
    Ken
  3. SlickMurphy
    Aug 18, 2004
    275
    Essex
    David
    Ken,
    Thanks, that's exactly the advice I was looking for!!
    David
  4. Bob Zambelli
    Bob Zambelli F1 Rookie
    3,672
    Manning, SC
    Robert G. Zambelli
    David - both the jobs you need to do are quite simple.
    If you wish, I can explain in detail how to change all your fluids.
    Feel free to call me at my office - 610 328 4000, ext 551, 8:00 to 5:00 DST.
    I would suggest Valvoline gear oil - it's the best I've ever used in the many Ferraris I've serviced. NAPA stores carry it.
    I would also suggest Castrol LMA brake fluid - it's the only one I use and the brakes in my 1967 ALFA and Ferrari have never experienced corrosion. DO NOT USE SILICONE.
    Bob Z.
  5. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    Well, not owning a 308 I wouldn't pretend to tell you how to do it; generally you just take the bottom bung out, drain, change the washer, replace. Fill through side bung with a gravy baster. They don't have seperate coolers or pumps to deal with so it's not like a dry sump oil change.
    I stand by my comment though. If I can do it, your "mechanic" ought to really figure it out.
    Ken
  6. Steve Magnusson
    26,931
    Post #12 in this thread lists one set of correct steps:
    http://ferrarichat.com/forum/showthread.php?t=12621&highlight=gearbox+oil+change+308
    You'll need 4 new Cu washers 22 mm ID x 27 mm OD x 1.5 mm thick (search on "Global Metrics" for prior threads discussing Cu washers). There are 2 drain plugs and 2 fill plugs -- see the GEARBOX section of your OM (or probably any 308 OM) for illustrations of the various fill/drain plug locations.
    Also review the figure for the GEARBOX-DIFFERENTIAL shown in the "LUBRICANTS AND LIQUIDS" Table of Section 1 in the OM. It shows how the transfer gear reservoir is a small pool area located above the main gearbox reservoir and why you can add all the new lube into the transfer case fill hole (per step 5) -- the excess overflows to fill the main reservoir. (Although it's also perfectly permissible to put the minimum of the 0.17 pints new lube, or any amount greater, in at the transfer gear fill plug and the rest in via the main fill plug.)
  7. dhs-9
    dhs-9 Formula Junior
    Feb 6, 2004
    292
    There is nothing wrong with the use of silicon as long as the system is flushed of the old fluid. Silicon fluid last indefinately and as long as you dont have ABS or track the car it will be more than fine. This topic has been discussed numerous times on this forum
  8. PeterS
    PeterS Five Time F1 World Champ
    52,560
    Goodyear, AZ
    PeterS
    Just don't drain the crank case thinking it's the gear box!
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,653
    San Carlos, CA
    Mitchell Le
    Vavoline SYNTHETIC gear oil.
    Makes your gear box shift like butter, when cold.
  10. kdf398
    kdf398 Formula Junior
    512
    Pasadena
    Keith
    Here is a thread which sets forth a procedure that I have used. It is from the website expensivecar.com:
    http://www.camerafilters.com/ec/gearbox.htm
    Re: Redline 75-90 NS. try Summitracing.com and search for part number RED-58304.
  11. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    I've bought the Red Line gear oil from Jegs (www.jegs.com). Sometimes, you can find it at a chain auto store or local parts store, but call around. Brake fluid, use Castrol LMA, unless you plan on tracking the car, in which case, consider a high temperature racing fluid. I personally don't like silicon brake fluid. Nothing special about bleeding the brakes. They bleed the same as most other non-ABS cars. Just be sure to pump enough fluid through to clear the lines and assure you have fresh fluid in there. Nothing gets your attention faster than unexpected brake fade.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    There are a couple of tricks for successful searching:
    1) Click on search, select 'advanced search' then enter in key words
    'change gearbox oil'
    select 'search 'Entire Posts' & 'Tech Q&A'.
    2) Lots more info in the old fchat. Select search old fchat then insert same words in 'search for'. select 'all words' & the 'Tech Q&A' topic, then repeat the search for 'Tech Q&A Archives'.
    Repeat for 'change transmission oil' & 'change transmission fluid'.
    You will end up with a diozen or so hits.
