How to check the water pump is running ok. | FerrariChat
Discussion in '308/328' started by magaoidh, Nov 1, 2009.
  1. magaoidh
    magaoidh Karting
    May 12, 2009
    220
    I am checking the condition and age of the cam belts meaning the alt. is disconnected,so is the water pump and the the coolant pipe has been swung out of the way.Spinning the pulley on the pump is quiet and smooth,so bearings appear good,no play!
    Without removing and dismantling the pump is there a simple way of checking the performance?
  2. eurogt4
    eurogt4 Karting
    Apr 15, 2006
    243
    Sacramento, CA
    If the bearings appear quiet and smooth, and there is no leakage from the weep hole, it should be fine.
  3. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    If bearings are OK, the only thing that could be wrong, and this is like really, really rare, is your impeller is loose or has corroded away, and that can only be checked by removing the pump and giving it a visual inspection.
    If you are chasing a cooling problem, the pump is about the last place I would look.
    Doug
  4. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    If the pump is old and you put a new belt on or re-tension the old belt, it will rapidly shorten the life of the pump. Once they age and settle in, the bearings just dont appreciate more tension. I cannot begin to recall how many water pumps I have replaced shortly after being nice and putting on new belts. I have had many, many water pumps on various engine's fail within days after a re-tension, some within hours the same day.
  5. magaoidh
    magaoidh Karting
    May 12, 2009
    220
    Thats encouraging!Thanks for the info guys!
    Geoff
