How to choose a 348 to buy? | Page 2 | FerrariChat
Discussion in '348/355' started by Ernesta_The_Guevara, Sep 8, 2024.
  1. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,227
    France
    The gearbox is a weakness, so in an old car it may have been already repaired (which will make it good until the next failure) and in any case it's something to look at.
    I did own a tb; even the ts (not having to go to the spider) is catastrophic in terms of (lack of) stiffness by comparison.
    Ernesta_The_Guevara likes this.
  2. DrStranglove
    DrStranglove FChat Assassin
    32,088
    Google Maps
    DrS
    I bought mine in 2002. Its a '94. I agree my maint cost average is about $500-$1000 a year. It came with 11,000 miles (unloved) and now has about 75k miles. That said, there were a few years here and there that it did not get driven at all.
    My Jag however....
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,958
    Richmond
    Pete
    You will have to compromise somewhere. My advice would be to compromise on cosmetics and color combo to get the most mechanically sound car you can. That's what will eat you alive cost wise, cosmetics/body work can be handled by non Ferrari specific shops without much sacrifice, the mechanicals are a bit more difficult for non specialists. If you want a red/tan car you will be paying more for a bad car, bad combination.
  4. Ernesta_The_Guevara
    Aug 31, 2024
    198
    Thanks for good advice! I had small experience on MR2, but better to say – i do not have experience :)
  5. Ernesta_The_Guevara
    Aug 31, 2024
    198
    Thanks, as i see all basic info is there
  6. Ernesta_The_Guevara
    Aug 31, 2024
    198
    Thanks for answer! 2-3k for maintenance isn't sounds much. More worrying question – it's big repairs. Labor cost doesn't that important, but partst can be.
    if the 348 has any common classic breakdowns? Like cracked crankshafts on a Land Rover? Something that happens fairly regularly and can be very expensive for parts?
  7. Ernesta_The_Guevara
    Aug 31, 2024
    198
    One more thanks for answer.
    Yes, mechanical part can make me worry. Cosmetics not really, interior only. Paint and restoration of external view isn't cost much compare to buying engine parts.
  8. Ernesta_The_Guevara
    Aug 31, 2024
    198
    Thanks so much for the reply! Are there any other similar things that are weaknesses in the car?
  9. Ernesta_The_Guevara
    Aug 31, 2024
    198
    Very-very cheap maintenance, any big repairs?
  10. DrStranglove
    32,088
    Google Maps
    DrS
    Ferrari Alternators are crap. I went through three then just replaced it with one from Japan. I has gone years with nothing more than an oil change.
  11. Ernesta_The_Guevara
    Aug 31, 2024
    198
    To be honest, sounds like magic. It's common or you have unique one, 348?
    Because everything what i ever heard about old Ferrari – it's extremely unreliable cars.
  12. Jose348TB
    Jose348TB Rookie
    Feb 9, 2024
    2
    Valencia, Spain.
    José María Barber
    #37 Jose348TB, Sep 9, 2024
    Hi.
    I bought mine at Spain, nearly one year ago ( so not too much experience) after performing the Time Belt change, checking compressions, all fluids changed, new gaskets, old tubes replaced, etc. I paid 5.000€ on an ex oficial Ferrari technician shop for that work were the car was maintained the last 20 years with previous owner( Fair price according hours, and Ferrari material).
    Check leaks, compressions, starting perfectly at first turn of key without pressing accelerator,A/C with no error codes on screen, maintenance invoices and maintenance book, owners manual, leather tool bag, all lights on the on the dashboard working ( some cars cancel two warning lights), check gear box ( second gear is hard until on temperature, so I go from first to third initially, I had to learn how to change gear with Heel/ Tip ), Check fuel gage ( early models have problems), runs on normal temp and psi, electrical side mirrors works, electric windows are slows but works, fans working after shutdown, paint in good condition or original…..
    So far no issues, and being confident in the car. I think that if has been well maintained is a reliable car of 35 years old.
  13. DGS
    DGS Seven Time F1 World Champ
    74,291
    MidTN
    DGS
    It's possible to go either way, as long as you're making an informed decision.
    I used to say that you should budget a quarter of the purchase price for the first service, whenever buying a used Italian car.
    There will be things the previous owner no longer notices that will annoy you.
    So the first service will often be large.
    When I bought my 328 in 1999, it had full service records, but hadn't been maintained very well for a couple of years.
    I had a full engine-out "make it right" service that did cost about a quarter of the purchase price.
    And it's been mostly trouble free ever since.
    (Other than the usual timing belt changes and shift shaft seals.)
    Of course, recently I've been having to update the fuel hoses, as cars from that era weren't built to run E10 ethanol fuel, and the ethanol can degrade the original production fuel lines.
  14. fdekeu
    fdekeu Formula Junior
    637
    Belzium
    Frank
    No mayor issues, never had a problem in 22yrs and *over 30K kms
    Worst thing that can happen is a failure of the timing belt. So be sure it has been replaced or
    service it after you buy it (using Hill Engineering bearings)
    Rear lights and the grill are rare and expensive!
  15. Ernesta_The_Guevara
    Aug 31, 2024
    198
    Thank you for such a detailed response!
    Your answers in general say that Ferrari is quite simple in relation to modern cars and there is nothing super specific in it, so you should not be afraid, but choose according to common sense.
  16. Ernesta_The_Guevara
    Aug 31, 2024
    198
    With quarter of price will be problems! :)
    Thanks for such complete answer
  17. Ernesta_The_Guevara
    Aug 31, 2024
    198
    as i understand, main thing – It's to check timing belts. In general nothing really specific compare to buying old car
  18. A348W
    A348W Formula 3
    Jun 28, 2017
    1,869
    North Wiltshire, UK
    no, biggest bills are belt changes.
    expensive failures can be heater ecu as they are hard to come by.
    at 348 age you will be into some suspension work at some stage but there is no rocket science there. also fuel lines/ pump rubbers but again its all standard mechanical stuff nothing special. as with clutch.
  19. Ernesta_The_Guevara
    Aug 31, 2024
    198
    Like with any car, what can legally drink alcohol :)
  20. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
  21. DrStranglove
    32,088
    Google Maps
    DrS
  22. Ricambi America
    Sponsor Owner
    DrS.... "The days are long, but the years are short". Sometimes I'd pay a king's ransom to roll back the clock 20 years. Other times, not so much.
  23. Ernesta_The_Guevara
    Aug 31, 2024
    198
    #49 Ernesta_The_Guevara, Sep 12, 2024
    I'm states for sure.
    In Romania maybe 1.5k :)))
  24. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,565
    Atlanta, GA
    Steve D.
    You have absolutely no idea what you're talking about. In fact, I don't think I've ever seen a postive toned post out of you....even on BaT.
    Shut. UP.
    sjd
    ...from a guy who bought a 348 off of CRAIGSLIST, and does ALL his OWN WORK.
    AceMaster likes this.
