How to clean carburators? | FerrariChat
Discussion in 'Technical Q&A' started by Helmut, Jan 7, 2005.
  1. Helmut
    Helmut Formula Junior
    Dec 11, 2004
    640
    This is another one of my questions along the crusade of getting to know my 78 308; I took off the airfilter-housing and the carbs look like they could use some cleaning.
    Is there a way to bring them back to their original shinyness?
    Thanks,
    Helmut
  2. Helmut
    Dec 11, 2004
    640
    Thanks for pointing that out to me, excellent threads.
    It seems to require the Carbs to be taken apart, which scares me since I don't think I could get them back together and adjust them perfectly.
    Is there a easy way to learn how to put carbs together and adjust them?
    Thanks,
    Helmut
  3. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    He, he, he. My brother is a british car mechanic. (John's British Car Garage, Reno, Nevada) I asked him about it. He just laughed and compared it to learning music. But once you get it, it's easy. I've never been able to get it.
    He, he, he,
    Bob Wassam
  4. Helmut
    Dec 11, 2004
    640
    Better leave 'em dirty seems to be the answer on this one... :(
    What a chicken am I though, I just saw Bert's 308GTS to GTO conversion (showroom section) and I almost fainted.
    "Home on the ranch" Euro style :)
    Helmut
  5. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    If you want to do them on the car just use simple green with a brush and wet rag. Plug the carb horns and take your time. Wipe down after with a wet rag and dry off. Takes a few hours but you should get the results you want. Just don't turn any screws and you'll be all right. Stay off of the paint as much as possible but the green stuff shouldn't do any damage .
  6. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Actually, it's been demonstrated that Simple Green isn't 100% safe on Al, it can oxidize it if not used carefully. Sholdn't be a problem, but I found that carb cleaner did wonders on the outside of the carbs as well! The only issue is the patience to get into all those nooks & crannies...
  7. Helmut
    Dec 11, 2004
    640
    Interesting, ... I certainly got more patience than knowledge at this point so there I go.
    Helmut
  8. Bryan
    Bryan Formula 3
    Right. From Simple Green FAQ at http://consumer.simplegreen.com/cons_faqs.php
    Aluminum - Is it safe to use Simple Green on aluminum?
    Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: Aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All-Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
  9. Helmut
    Dec 11, 2004
    640
    Thanks for all the info!
    I was wondering, is there a specific reason why nobody mentions WD-40?
    Thanks,
    Helmut
  10. bwassam
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    WD-40 is corrosive to aluminum. I use mineral spirits (Paint thiner) to clean the aluminum skins and engine parts on my airplane.
    I'm in the process of buying a '77 308 and thought I'd do the same thing with it, when I get it, to clean the outside parts of the engine and drive train. I use an air wand that sprits the metal with the spirits while using compressed air to get into the nooks and crannies and blow out the dirt. I use a stiff paint brush to get into the stubboran places. The residual spirits evaprotats away. Make sure you have good ventalation. The air wand can be gotten at Chicago Freight for $5 buck-a-runies. You do need to get an air compressor. Cheap ones can be had for $150 or so. That's all you need.
    I make the paint brush stiff by cutting the bristles to about half their normal lenght.
    Bob Wassam
  11. Helmut
    Dec 11, 2004
    640
    This sounds very cool;
    Regular painthinnner won't do any harm to bearings etc.?
    Thanks,
    Helmut
  12. bwassam
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    Hasn't hurt the seals and bearings on my Mooney. It's a 1963 C model. My FAA guy (IA) that signs off the airplane showed me how to use it. The seals on the Lycomming engines are similar to any other engine. All it does to the rubber parts is clean them. Ya gotta be sure to re-lube all your moving parts like linkages and cables.
    If you have any doubts get an old rubber seal and wet it down in the thinner to see what happens.
    I'd be careful about getting it into your intakes though. I don't think it burns properly for a Ferrari.
    I use a Chevron product called "Handy Oil" to lube the bell cranks and control rod ends and joints. It's got good penetration and staying power. It cost about $50 for a five gallon can. You have to go to a distributor to get it though. I also wipe down the insides of the wing panels and tail cone with it help prevent corrosion. After awhile it dries and the residual leaves a nice barrier against corrosion. I don't plan on wiping down the Ferrari with it though. I'll just use it to lube the linkages. Five gallons will last one guy several years. I use it for nearly all my light oil needs.
    Any chemical engineers on the forum?
    Bob Wassam
  13. F308 MAN
    F308 MAN F1 Rookie
    Jan 19, 2004
    2,907
    Isle of Man
    Dave S
    in the absence of "berrymans carb dip" here in the UK, i am awaiting a delivery of 2 gallons of xylene (preferred to methyl ethyl ketone).
    does anybody disagree with my choice ?
    cheers, d
  14. Bryan
    Bryan Formula 3
    A bit rambling below...
    Both have their downside as far as health risks.
    MEK will probably be a better cleaner, but I would still use the xylene myself.
    Berryman Carb Cleaner (not the dip) has both, as well other fun chemicals.
    http://www.berrymanproducts.com/msds/0101-0105-0116-0155.pdf
    Xylene Personnel Exposure Limit is half (twice as bad) the value of MEK.
    MEK is a serious paint stripper; xylene much less so. Xylene is in Carb dip, MEK is not. However, the bad actor in Carb dip (and what makes it harder and harder to find, unless you are a professional mechanic) is dichloromethane, a carcinogen. But the other constituents are quite hazardous too.
    Xylene (mixed)
    http://www.setonresourcecenter.com/dtSearch/dtisapi6.dll?cmd=getdoc&DocId=228355&Index=D%3a%5cINDEX%5cHMIS&HitCount=10&hits=3+6+57+dd+3dd+454+492+4c4+4f6+517+&SearchForm=D%3a%5ccrc%5cmsdss%5ccomply%2ehtm
    MEK
    http://www.setonresourcecenter.com/dtSearch/dtisapi6.dll?cmd=getdoc&DocId=209841&Index=D%3a%5cINDEX%5cHMIS&HitCount=30&hits=3+4+5+9+a+b+5f+60+61+11a+11b+11c+143+144+145+471+472+473+4dd+4de+4df+51c+51d+51e+588+589+58a+5ab+5ac+5ad+&SearchForm=D%3a%5ccrc%5cmsdss%5ccomply%2ehtm
    Berryman's Chem-Dip
    http://www.berrymanproducts.com/msds/0901-0902-0905-0996-0955.pdf
    Hope these links work, if not go to http://www.setonresourcecenter.com/MSDSs/comply1.htm
  15. F308 MAN
    F308 MAN F1 Rookie
    Jan 19, 2004
    2,907
    Isle of Man
    Dave S
    thanks bryan ... i am impressed with your data, thank you !
    cheers, d
