How to clean rear hub carrier | FerrariChat
Discussion in '308/328' started by mixedgas, Oct 3, 2024.
  1. mixedgas
    mixedgas Formula Junior
    267
    Ramona, CA
    I've cleaned these with a good solvent tank (not the water based crap), and then paint thinner, stiff brush but still looking dirty. I think it's undercoating but not dissolving with the solvents I've tried. Should I bead blast it? I was going to just spray paint it, but not sure paint will stick to the staining. Considered NAPA aluminum bright too. Any thoughts welcome. Thanks!
  2. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    214
    Boerne, TX
    Rodney Bolt
    Brake cleaner?
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,328
    Dumpster Fire #31
    SMG
    That's cooked on and in the pore structure of the casting. Soda blasting might get it. I don't care for glass on aluminum cast parts personally. To easy to cut thru masking and touch machined surfaces. And cleaning out the glass is not always a guarantee.
    I've soda blasted them on a few that owners didn't want to leave them looking dirty. They came out ok, not 100% perfect though. Otherwise, leave it be. It's just stained and has no ill effect on the part.
    Aluminum oxide layer is very tough.
  4. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    There’s also an ice based process that’s perfect for parts that size which is gentler than soda, sand and glass and from what I’ve seen restores a more “as cast” look. Guys have used in on the euro cam covers which are a very smooth casting and which no owner wants to sand blast and get ruined.
    smg2 likes this.
  5. stoked_7
    stoked_7 Karting
    214
    Dry ice blasting
  6. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    I can’t remember if it’s dry ice but likely yes. It was fairly proprietary a few years ago and few were doing it. There is a thread somewhere here in 308 that discusses it and pictures included. The first guy to show it off was an aussi. I (had) found a couple places in Phoenix that could do parts under 2 feet length. So no engine blocks but cam covers etc would fit.
  7. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    vapour blasting uses a slurry and can restore luster to cast aluminum
    Du_Man likes this.
  8. moysiuan
    moysiuan F1 Rookie
    4,186
    Canada
    Try wiping or even an overnight soak in acetone. If that doesn't work, you will need acidic or mechanical abrasion, neither which is great for the casting, and would be best left alone, or just paint with a silver/aluminum look brake caliper paint.
  9. Imatk
    Imatk Formula Junior
    May 6, 2007
    768
    I got most of mine out with a pressure washer, but the deep stuff is just in there. I wouldn't blast it personally since it's behind a rotor and can hardly be seen. But up to you I guess.
    I also wouldn't paint it personally either but again up to you :)
    This is how much you see of it when everything is installed.
    mixedgas likes this.
  10. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    I did mine with low pressure (~40psi) glass bead blast after masking the machined surfaces. Then coated with ACF50. Looks new. I do almost all rough cast aluminum this way.
    mixedgas and Cameron Henlin like this.
  11. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    545
    NYC
    Joe
    Zenobie, mixedgas and smg2 like this.
  12. 85QVEuro
    Jan 15, 2021
    545
    NYC
    Joe
    Zenobie, mixedgas and moysiuan like this.
  13. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    That’s what I was trying to remember. Vapor Blasting. Proprietary if I recall but works perfectly on Ferrari aluminum. Started with motorcycle restorers.
