How to clone a black remote fob .... | Page 13 | FerrariChat
Discussion in 'Technical Q&A' started by eric355, Dec 15, 2006.
  1. Argento360
    Argento360 Karting
    Mar 9, 2006
    177
    CA,AZ,NV
    #301 Argento360, Mar 12, 2012
  2. Kwilson
    Kwilson Rookie
    Mar 31, 2012
    2
    Reading, UK
    Kurt
    Hi Eric, I am based in the UK and recently bought a 360 with only one black remote. Would you able to programme a spare remote for me if I bought one? Could you emal me and let me know the process and cost kurt[at]advansys[dot]co[dot]uk
    Kurt
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,710
    South East
    Jimmie
    If Eric is out of Euro fobs for cloning a friend can supply them - send pm
  4. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    Who carries the red fob leather covers
  5. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
  6. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    Yes but in RED
  7. ttdang123
    Nov 28, 2009
    706
    North San Diego CA
    Tung
  8. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
  9. wspi
    wspi Rookie
    Nov 8, 2003
    18
    United States
    Wayne P.
    Thank you Gobble (Mark).
    I received three working fobs today!!!
    Thank you for supporting the community with your services.
    Take care.
    wspi.
  10. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    #310 eric355, Jul 31, 2012
    Tonight, while trying to make a set of fobs for an owner who sent me 3 Ford fobs, I discovered that those ones are not compatible with the Ferrari ones.
    Both models are made by Bosch, use the same case but the internals (PCB, IC, ...) are not the same. Those Ford fobs use the old fixed code technology with PCB tracks cutting.
    So, be careful, some Ford fobs are compatible (cf post #172), some are not ...
  11. f355spider
    f355spider F1 World Champ
    18,055
    Is there a simple way to differentiate the compatible Ford ones, from the ones that are not compatible? Part numbers or lot numbers?
  12. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    "RK 112" printed on the back, if still present, is probably the easiest way to differentiate the models.
    If not, a look at the PCB is necessary.
  13. cl65
    cl65 Rookie
    Aug 1, 2012
    19
    Sweden
    David
    #313 cl65, Aug 12, 2012
    eric355: How do you know if the fob is Us or Euro Model? (My 355 is Euro)
    I have 3 fobs(2 red and 1 black). 1 red and the black works. The red one with the "tag" on it does not work.
    I have seen fobs that say RK112 and other ones with RKY112.
    Does this have anything to do with Euro or US?
    I have more questions if someone can give me an answer :)
    What happens if you turn the right pin with the key and then turn it another 12 times to get into programming mode for fobs and you try to for example program my 3 keys.
    First the red one that I for sure know works, then the black and then the red that dont work today?
    Can I in someway confuse the system so no keys work(if I for example tries to program only 2 keys or if I try to program 2 reds and 1 black)?
    Many questions, but I hope someone can give me a for sure answer before I try this procedure.
    If someone is sitting on a blank 355 key or a black euro remote I could really have use of them as you can see on the pics :)
  14. greyboxer
    Dec 8, 2004
    12,710
    South East
    Jimmie
    The middle one (which I think is the one you say does not work) is German so it is European - they can only be cloned to work - it cannot be reprogrammed using the procedure
  15. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    The best way to be sure if you have Euro remotes is to open them and to read and report what is written on the round metallic component close to the battery. If you see "2632" that means they are working at Euro frequency.
    Have you the correct PIN for your car? Are you able to start her without the remote?
    If no, I would clone one of your working remote in the one which is not working (provided it is at the correct frequency)
    If yes, you can either have your non working remote cloned as above, or I can make with your 3 remotes a complete new set with its PIN that you could program on your car.
  16. cl65
    cl65 Rookie
    Aug 1, 2012
    19
    Sweden
    David
    greyboxer and eric355: Thank you for your answers.
    eric355:The black remote work fine but one red does not work.(working red stay in the safe if possible?)
    Is it possible to clone a red one with use of the black?
    I have also read about "cloned" remotes that will have to "relearn" with pushing the button many times. Is this an issue only with cloned fobs?
    My question is: Will a cloned fob work as perfectly as a "real" one?
    You are most welcome to mail me details on both procedures and which one you think is the best solution for me.
  17. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    There is no problem to clone a red from a black. You will get a black in a red case.
    The working red has no particuliar value compared to your black, now that it has already been used to communicate its PIN to the ECU.
    You are right about this small drawback of a cloned remote. Because it shares the exact same ID than the original remote, it send the exact same codes. All the already sent codes being rejected by the ECU, that explains why you have to press several time a clone, or the original, when you want to swap from one to the other. Once a clone send new codes, it works exactly as a real one.
    You have not answered about the current PIN. Do you have it?
    Supposing yes, you have the 2 options I explained. Cloning your not working red will be cheap, making a new set with its PIN from your 3 remotes will be a bit more expensive.
  18. cl65
    cl65 Rookie
    Aug 1, 2012
    19
    Sweden
    David
    eric355: Yes I have the PIN, but maybe cloning still will be the best way to go?
    Will the original remote that works and which you use to make the clone still be "original" and not share drawbacks of a cloned remote?
    If you could mail me differences in price and more important information it would be much appreciated.
  19. Hoodude
    Hoodude F1 Rookie
    3,454
    North Carolina
    RE
    Mark (Gobble),
    Got the fob a minute or so ago..works fine.
    Red looks good!
    Thanks again.
    Cheers,
    RE
    Ps,I'm another happy customer...
  20. cl65
    cl65 Rookie
    Aug 1, 2012
    19
    Sweden
    David
    Hi again
    Eric is helping me cloning my fob.
    While I have 2 reb fobs and 1 black(see picture a couple of posts above) I would consider to trade 1 red vs 1 black.
    I guess the red is "harder" to get so hopefully there are someone sitting with 2 or 3 black ones and need a red one. The trade is only for the shelf(not the electronics).
    I have the red shelf and you the black :) The trade is only for the shelf/cover so if your black fob is working you will get a red working one....
    My english is not perfect but I hope everyone understands. Otherwise help me someone :)
  21. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I got my hands on a few new red fobs if anyone is looking to add one to their system.
  22. BenchBoy
    BenchBoy Karting
    Mar 30, 2012
    113
    Gino
    Gobble I got the fob today and it works well! thanks
  23. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    And I also have one new black fob. I'm running low and they're getting harder to find at a decent price.
  24. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    Will the Red fob allow programming of other remotes or is it just a clone ? (I don't know my pin).
  25. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    It's just a clone. The red for only serves the purpose of programming a new set of three into the car that first time. Even with the PIN, you can't use it to add a single additional fob.
