How to clone a black remote fob .... | Page 8 | FerrariChat
Discussion in 'Technical Q&A' started by eric355, Dec 15, 2006.
  1. maranello72
    maranello72 Formula Junior
    Jul 4, 2009
    354
    Munich, Germany
    Stefano
    Gobble,
    I've bought it on german eBay, Euro spec (like my 550)!
    Stefano
  2. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Is this the solution for on-board programming?
    http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4406
    By the way, if anyone is considering buying their own programmer, don't buy the true USB willem. I replaced my universal willem with this because it is supposed to be easier to use and I can't properly read the 93C46 chips with it. I need to go buy another universal willem.
  3. tazandjan
    39,315
    I think I will buy one of those for Eric if he wants one. He is 100% on soldering so far, but this will make it even easier.
    About one more red fob and PIN and we will be able to discern the PIN in the red fob EEPROM read-out, I think.
    Taz
    Terry Phillips
  4. 12659
    12659 Formula Junior
    Oct 6, 2005
    349
    Seattle WA. USA
    mark
    Is there a way to imobilize the imobilizer? I suppose the whole pont of the system is to prevent that from happening. I hate these fob things... beeping and batteries and hassles.
    However, if I must, a clone it will be.
  5. tazandjan
    39,315
    Some of the earlier cars, yes. I do not have any specifics on who can do the work, though.
    Taz
    Terry Phillips
  6. eric355
    eric355 Formula 3
    1,234
    Toulouse (France)
    Eric DECOUX
    Thanks Terry but I dont really need one. You know, it takes me about 30s to remove the EEPROM and about the same to put it back on the board. As I dont clone thousand of remotes per day, it is not a problem at all :)
    I thought I could have access to a red and its PIN, but no luck, I have no more news from the owner ...
  7. tazandjan
    39,315
    Eric- I have a red and PIN coming from an owner I helped. Will send both to you when they arrive.
    The new owner of the set of three we produced is very happy and had no trouble programming the ECU to accept them.
    Taz
    Terry Phillips
  8. eric355
    eric355 Formula 3
    1,234
    Toulouse (France)
    Eric DECOUX
    Great news Terry. Thanks.
  9. maranello72
    Jul 4, 2009
    354
    Munich, Germany
    Stefano
    Yes, that blue clip looks just like the one I'm using (I made the adapter cable myself). But cut the wires to pins 6 and 7 to avoid read/write problems when connecting to the EPROM on-board!
    Stefano
  10. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    And I went back to the old version of the Willem programmer and everything works fine again.
  11. tazandjan
    39,315
    Someone told me you were having problems. Back in action again?
    Taz
    Terry Phillips
  12. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Yep, I bought a new programmer that was supposed to be better and easier to use and sold the old one on Ebay. The new one had trouble with some of the 94C46 chips. I bought a "new" old one and it works fine, cloned one last night and it worked just fine.
  13. maranello72
    Jul 4, 2009
    354
    Munich, Germany
    Stefano
    For those who don't have the original PIN, it seems it might be possible to read it from the ECU with this device:
    http://autocheery_alice.en.ecplaza.net/8.asp
    On the 550 it seems stored on a 24C04 EEPROM, on the 360 and 575 on a 24C02, very similar devices to those inside the key fobs.
    In fact, if you were prepared to open the ECU you could probably read the content of the chip on-board with the same setup used to read the key fobs.
    The only question remains of course - where do you find the PIN among the 4Kbits of data that the 24C04 holds???
    Any thoughts?
    Stefano
  14. tazandjan
    39,315
    Stefano- We are just at the point where we think we can read the PIN in the red fob. There is a lot more data in the ECU, so no clue.
    Taz
    Terry Phillips
  15. maranello72
    Jul 4, 2009
    354
    Munich, Germany
    Stefano
    That's good news Terry!
    If the PIN is known and it is not crypted in the ECU's 24Cxx immobilizer chip, it should be easy to find. After all it only contains 4kbits=512 characters...
    Stefano
  16. dano360
    dano360 Rookie
    Jun 25, 2010
    3
    Eric, This is my first thread cause I am new to FerrariChat.
    I have an 03 360 with two red remotes one that works and one that doesen't, I have read alot of the threads and understand the programing of a new three remote package, but wanted to know if I can program, clone, the other red remote to be a slave.
    I have the original pin and was worred that I might install the pin from the non working red remote accidentally then be SOL.
    Or am I going to have to buy a black remote?
    Could you explain to me how to do this? also if I have to buy a black remote can I use say one from ebay? and go through the original set up to program it?
    If there have been other black remotes programed before will the ecu except more remotes?
    Lots of questions for my first time. Thanks
    Danny
  17. tazandjan
    39,315
    #192 tazandjan, Jun 27, 2010
    Danny- There is no difference between a black and red remote internally. The only difference is what is written to the erasable EPROM in each fob. If your other red remote still illuminates the red LED when depressed, it can be cloned to your operating red remote that does work. You would then have two red remotes with the same PIN inside, not that having the PIN inside makes any difference.
    There is no way to accidentally do anything with your inoperative red remote. The PIN in your operating red fob is also in the Alarm ECU. During normal day to day use, the PIN is not employed at all by the Alarm ECU. After original programming for a three fob set, the PIN in the red fob is not used at all. Its initial transmission to the Alarm ECU during programming is the only time a PIN in a red fob is used. After that initial programming, the Alarm ECU only looks for PIN IDs and the rolling codes in the fobs' EEPROMs.
    Read this and see if you have any more questions.
    Taz
    Terry Phillips
  18. eric355
    eric355 Formula 3
    1,234
    Toulouse (France)
    Eric DECOUX
    #193 eric355, Jun 28, 2010
    Danny, Terry wrote the complete story ... :)
    You can clone your extra red remote, no need to buy a black.
    The ECU will not accept any other remote with the current PIN. You would need another set of remotes with a different PIN to be able to reprogram the ECU with new remotes.
    Also, there is no risk at all to install the wrong PIN by simply pressing the wrong remote around your car ... fortunately ... otherwise, imagine what could happen in a Ferrari meeting :)
  19. dano360
    dano360 Rookie
    Jun 25, 2010
    3
    Thanks Terry and Eric, I still have questions... So for me to use my second red remote... can I program it by using the orginal pin and red remote and go through the programing setup, or will I have to get it cloned another way? If I can do this can I add one another black remote at that time?
    Terry in your attachment on (how to program) It says a red fob and it's pin can only be used to program the alarm ECU to except a matched set of three alarm fobs.The red fob cannot be used to program the alarm ecu to except other black alarm fobs that were NOT part of a matching set of three fobs. Danny
  20. Skidkid
    Skidkid F1 Veteran
    9,629
    Campbell, CA
    John Zornes
    You asked the question and answered it directly from Terry's document. The fobs come as a matched set. You can not mix and match fobs so you can not program another black with your red. You can not program 2 red fobs into a system.
    You can have your fob cloned so you have 2 fobs. You can purchase a set of fobs and use the PIN to program the new set.
  21. tazandjan
    39,315
    John is correct. Read the document and it explains all that in dumb fighter jock language, because that is what I am.
    Eric can clone your extra red fob to your working red fob. You have no other options with the extra red fob except to sell it and use the funds towards a new matched set of three fobs with new PIN.
    Taz
    Terry phillips
  22. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,707
    South East
    Jimmie
    Just to be completely complete : yes any number of blacks or reds can be cloned to your red
    Do not forget your sole original needs to be sent for the cloning so find three or four weeks you do not intend to use the car
  23. dano360
    dano360 Rookie
    Jun 25, 2010
    3
    Thanks for the info, I did read it, I guess I could have saved everyone a lot of grief if I had known the difference between cloneing and programing... duh.
    Danny
  24. Skidkid
    Skidkid F1 Veteran
    9,629
    Campbell, CA
    John Zornes
    No problem.
    Programmed is associating the fob with the car's alarm system.
    Cloned is taking it apart and changing the program in the fob to match another fob. It is now an identical twin to the other fob. Hence the term cloned.
  25. MGonz540
    MGonz540 Rookie
    Jul 3, 2010
    24
    South Texas
    MG360
    Please forgive my ignorance. I own a 2000 360/US spec. I only have one working remote (black). I took a chance and purchased a red FOB from Ebay. I bought a new key from my dealer. I do not have my PIN. It seems I need an act of congress in order to get my PIN. Can I get my new red FOB programmed? If so, by who? I will be happy to pay for this service. My nearest dealer is over 250 miles away. This is a very irritating problem for me. Any help is appreciated.
