how to cut and fold photoetch parts? | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by bigodino, Sep 12, 2010.
  1. bigodino
    bigodino F1 World Champ
    13,193
    The Netherlands
    Peter den Biggelaar
    I've been preparing for building the F40 LM in 1/18 scale using APM kit and Tremonia photoetch parts. I've searched the internet on how to cut the PE parts off the fret and how to fold them. I discovered the 'hold and fold' tool but this is quite an expensive one for something I won't use that much.
    Are there other tools and ways to get the parts cut clean and to fold them?
    Thanks, Peter
  2. moriaan1
    moriaan1 Formula 3
    Dec 3, 2006
    2,330
    Netherlands
    Hans
    Sharp scissors to cut them from the window, and for bending I use different wooden
    cilinders in various diameters and blocks.
    Over the years I made several different shapes and sizes using hardwood.
    Hans
  3. zoRob
    zoRob Formula 3
    Oct 31, 2006
    2,004
    Cambs, UK
  4. gcalex
    gcalex Formula Junior
    611
    Mostly New Hampshire USA
    Alex
    The trick with using a knife is to use a heavy-gauge *curved* X-acto blade, and a hard flat surface (one of the best is a "Corian" (yes, the fake granite/marble stuff for kitchen counter tops) sample that you can buy at any Home Depot.
    Place the frame on the Corian, use low-tack tape to hold the part in place (lest it go flying off to be lost in the carpet), and then *roll* the edge of the blade over the cut point (use low-ish pressure, and repeated rolls over the cut point). After maybe 6-10 rolls, the part should pop cleanly off...
    Be sure that if the parts have some sort of pattern etched into them, that the flattest side of the sprue to the surface that is placed against the Corian.
    Cheers,
    Alex
  5. zoRob
    zoRob Formula 3
    Oct 31, 2006
    2,004
    Cambs, UK
    Thanks, ill have to give that a try. I was doing it on my cutting mat which probably didn't help.
  6. gcalex
    611
    Alex
    Yes, a cutting mat will be way too soft.
    While something really hard like the Corian is best, it will dull the blade pretty quick. This is why I say that you need to use relatively light pressure; enough to work through the sprue, but not so much that you flatten the blade on each cut.
    Depending on the specific part, it is sometimes just as effective to use a block of maple (again, go to Home Depot and get a hardwood-flooring sample). This will dull the blade less, but in some cases will still be just a touch too soft a surface.
    Cheers,
    Alex
