How to determine OEM leather color #? (re: Leatherique) | FerrariChat
Discussion in '308/328' started by ducowti, May 23, 2012.
  1. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,557
    NY/SC
    David
    I'm inspired by the recent front-end respray of my 328 and a few threads here of leatherique successes to do my leather. Searched here but didn't find color # for crema as in my 86 Euro.
    How can I determine?
    Thanks!
  2. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Did you call them to see if they have the color formula? The other options are to cut a swatch of leather from somewhere on the car that will not be missed, and that is the original color and send it to Leatherique. They will match the color.
    Or, plan on redyeing all the leather in you car using one of their "stock" colors.
    I just redid my leather with Leatherique and the outcome exceeded my expectations.
  3. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Could you send pics of the Leatherique work? I'm still trying to make the choice between that and a redo.
    Lester
  4. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Redying is not a good answer although it is economical. A re-dye will always look dyed. If you can come up with the bucks to do it and you go to a place that does it right you will first look at swatches from different dye lots. There's dozens of different hides that claim, for example, to be tan. Grains vary a lot also. Your upholsterer will then cut the pieces from original hides using the old ones as patterns. This is completely new upholstery, not seat skins or kits. Its great to have concours paint, etc. but the cockpit is what you see when driving. This is the way to do it right and good craftsmen are hard to find. And, as I said, it's not cheap! Figure on $4K to $7K. Here's the thread I posted when mine was completed
    http://www.ferrarichat.com/forum/sho...light=interior
  5. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    The Crema color is actually Connolly #3997 Magnolia. Not sure if this helps.
  6. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,557
    NY/SC
    David
    Certainly does, thank you!
  7. DNJS328
    DNJS328 Formula Junior
    Aug 25, 2011
    323
    Arlington, TX
    Don P.
    Don't take the cheap way out here. You just purchased an amazing car. I bet you did not go with the cheapest one you could find.
    I just went through the same thing with my 328. The exterior is immaculate but the interior was warn. I thought about repair and dye but opted for a complete redo. New leather and carpet. It really makes the car stand out. It was expensive but worth it. If you are thinking about the investment, I will get you the leather number which is the current OEM leather color. Enjoy your new car this summer and prepare for a winter project.
    Good luck!
  8. The Kook Abides
    The Kook Abides F1 Rookie
    Jan 4, 2011
    3,459
    A re-dye done correctly will NOT look like it has been done.
    It does take a lot of patience and prep work.
  9. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,142
    Atlanta
    Tom Spiro
    I agree its all in the prep work. To make sure it looks great - you should re dye all the leather...
  10. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Well.. now that you mention it.... ;-)
    .. ok, so just to be sure, seats are leather, console cover is leather as well? How about door cards, leather or vinyl?
    I have only seen one car in person that had been re-colored. It was uniform in color and it had a *flat* appearance to it. It just didn't look right. So I'm partial to getting the leather redone.
    Lester
    Lester
  11. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    The original leather was treated, embossed and sprayed with dye anyway by the manufacturers. So if done properly its pretty much replicating the original processes.
    One downside though is if the stitching is dyed as well thats a bit naff.
    The exception is if the leather is cracked. I used to live around the corner from the original Connolly works in SW London and I took a car I owned to them once to have a look at. It had badly cracked leather. The guy said absolutely nothing could be done to cure this other than replacement.
  12. mwr4440
    58,005
    Bavaria, The 'Other' Germany
    Mark W.R.
    Pull a seat and look underneath.
    The original color will very likely be revielled.
  13. TacElf
    TacElf Formula 3
    Aug 15, 2010
    1,719
    Seattle area
    Jeff
    Having the leather redone rocks. Even though some of the restoration/dye jobs I've seen on this board and in person look really good, there is nothing like brand new leather. Even after 5 years, the work Bullfighter had done on this car still looks, feels, and smells new.
    It's expensive but it is sooooo worth it.
  14. ClydeM
    ClydeM F1 World Champ
    11,954
    Wayne, NJ
    Clyde E. McMurdy
    My interior was natty. I thought about a respray on the seats & even bought the dye from leatherique.
    But it became apparent that the tan wasn't consistent in the car. The seats were different from the door panels were different from the console, etc. All due to age & sun.
    Dye one thing, dye them all.
    My driver seat had a nasty split in the center. That twisted my arm to get an new interior from Bradan. It looks incredible!.
    Every one of the shops I visited for the seats warned me against dying, saying it'll start flaking in 3-5 years - guarenteed.
    Just an FYI.
  15. DNJS328
    Aug 25, 2011
    323
    Arlington, TX
    Don P.
    I had new leather put on the seats and center console. The leather on the doors was still good so I did have them dyed. I agree, if done right and the base material is good it can be done to look good. The item that stands out the most and you will get the most benefit is from the seats. Nothing like the feel and smell of new soft leather.
  16. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    the bottom part of the seat on my car, blue interior, was ripped. i cut a swatch, about 2 inch square, from under the seat and sent it to leatherique.
    bought a tan colored hide off ebay and took it to the upholsterer who cut portion he wanted to use.
    did the re dye spray myself that was six years ago and it still is perfect.
    whole job dye, leather, work came in under $500
  17. 308 GTB
    308 GTB F1 World Champ
    11,736
    New Jersey
    Barry Wolinsky
    It's hard to believe it's been five years! I think that's the last time I used the word "incused."
  18. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,605
    San Carlos, CA
    Mitchell Le
    Remove one of the door panel (or any other panel that you want to keep original), send it in for a color match, it is their job to match it with a guaranty.
    Twice now they did not match my samples and I have to redo all the leather in the slightly off new color
  19. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    #19 pad, May 25, 2012
  20. lem321
    lem321 Karting
    Mar 7, 2009
    91
    San Francisco, CA
    Wilson Lem
    PAD,
    Did you refinish the door panels too? Any pictures of the refinished central console and door panels. Did you use a standard Leatherique off the rack color or a custom one? How long did it take you.
    The seats look fantastic by the way.
    Thanks.
    (also an '83 owner)
  21. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Yes, I redyed the door panels. I recovered the console because it was in bad condition, and then redyed that too so everything would match. I used one of Leatherique's stock colors. I have no idea on the number of hours - there's more wait time than actual "work". And we used an air gun to apply the color. I had a local interior shop make new carpets (about $500), and then Steve (Fasterisbetter) and I spent about a day putting everything back into the car. Very happy with the results. I'm sure the concours folks will find flaws, but frankly Scarlette, I don't give a .........
  22. magnum
    magnum Formula Junior
    Feb 21, 2008
    877
    Barcelona, Spain
    Antonio
    To dye my seats and central console I've used the Leatherique colour code 3218, the beige one. The Crema is lighter. The beige is darker and more yellowed, the same colour that you can see in my picture of the link. These are my seats and my central console redyed with Leatherique 3218 -also an 83' owner, GTS-.
    https://lh6.googleusercontent.com/-_oZxtOED3UE/T8JuL48cewI/AAAAAAAAAR8/DJ0QOOI6yOg/s1024/IMG_4864.JPG
  23. The Kook Abides
    Jan 4, 2011
    3,459
    #23 The Kook Abides, May 27, 2012
  24. Huskerbill
    Huskerbill F1 Rookie
    Sep 6, 2004
    4,126
    Oconomowoc, WI
    Bill
    Wow!
  25. nickm
    nickm Formula Junior
    Jan 20, 2004
    378
    Ventura Ca.
    I did a set of seats also about 2 years ago in a GTB that I had. Leather was in fairly nice cond. to start with but TOTALLY faded. Take your time and follow the Leathique instructions and they will turn out VERY nice. I'm pretty picky and I was astonished how nice they turned out. The leather even softened up (quite a bit). It was amazing how the before and after looked so different. Big time faded leather. You may have to do the door panels and center console because the colors will be so mismatched. I have a video that I took of the car on Youtube (selling it) that shows the seats up nice and close if you're interested to see. Maybe shows a little better than photos. You do have to sit through a semi-long video to see shots of the seats though (nice close-ups). hehe
