how to dirve a Dino? | Page 2 | FerrariChat
Discussion in '206/246' started by raywong, Dec 16, 2006.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    My engine starts very quickly, the quality of spark must be good, the fuel pump must be ok too.
  2. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    The engine may start right off and your spark may be quite good but that does not mean nothing is wrong with the ignition. Its easy to check, a cheap timing light will do it for you, start the motor and look at the timing marks as you rev the motor, if your advance weights are not perfect you will get that stumbling you are getting.
    Just like the accelerator pump not working as I mentioned in my earlier post, checking the ignition advance curve and checking the accelerator pump function is free and easy to do.
    In my personal opinion, the ignition advance system is a weak point on these cars, it requires regular lubrication to keep in proper working order and the advance curve is pretty critical for these cars to run smoothly.
  3. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    Thanks! I will mention to the mechanic about the fuel pump and advance weights. I think he already changed my rotor points not too long ago.
  4. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    Just a quick clarification, its not fuel pump that I am talking about its the accelerator pumps, 3 of them, 1 in each carburator.
  5. robwill2
    robwill2 Rookie
    Apr 13, 2006
    5
    Why would you ever find yourself at 2000 rpm while driving
    a Dino except when accelerating from a standstill?
    If you like to drive, upshift at 7000+ and downshift, with
    a good blip, at 3500 to 4000. That's how it was made
    to be driven.
