How to disassemble 355 fly wheel / cluth | FerrariChat
Discussion in '348/355' started by yelcab, Feb 1, 2016.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    #1 yelcab, Feb 1, 2016
    I could only find a detailed procedure for a 348 unit, which is 50% different from the 355 unit, so here is the 355 procedure.
    1. Remove the pumpkin from the car, doh
    2. On a work bench, remove the little square 3x3 inch cover. 4 M8 nuts, 13mm socket
    3. Use a very strong impact wrench, 1/2 IR, and the tool below, zap out the large 4 prong nut.
    4. I had to press out the flywheel from the pumpkin, YMMV
  2. yelcab
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    #2 yelcab, Feb 1, 2016
  3. yelcab
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    #3 yelcab, Feb 1, 2016
    11. Improvise a puller using 2 pressure plate bolts, washers, spacers, and a metal plate from Home Depot
    12. Pull out the flywheel
  4. yelcab
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    #4 yelcab, Feb 1, 2016
    13. Turn the balancer unit over, remove 2 M10 plugs.
    14. Remove 6 M6 bolts from the housing
    15. Use two M10 x 1mm bolts to press out the balancer cover
    16. Clean everything well.
  5. yelcab
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    #5 yelcab, Feb 1, 2016
  6. yelcab
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    #6 yelcab, Feb 1, 2016
  7. yelcab
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    24. Press the housing back on
    25. Use an impact wrench, install the large 4 prong bolt with Loctite
    26. Clean up your flywheel surface
    27. Install a new clutch plate and a pressure plate (your mileage may vary)
    28. Put it back in the car.
    Warning: you want to mark everything and put them back the same way. Just in case.
  8. WATSON
    23,868
    WI
    Damn man. You are on a roll. Awesome!!!
  9. LorenzoR
    LorenzoR F1 Rookie
    Yea nice write up
  10. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    excellent write up
  11. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    nice, thank you.
  12. Yassa
    Yassa Formula 3
    1,266
    London
    Dr Yassa Hughes
    Great write up :)
  13. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    I don't think I have the cajones to try this but then again I didn't think I could pull the axle shafts either and I did great lol
    Thanks very much for this great write up.
    Not to look a gift horse in the mouth and in the interest of making this the definitive write up, could you show the install or removal of the pumpkin?
    Also, I've read it's common to change some seals (triple?). Maybe discuss that as well? Throw out bearing?
  14. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    I don't think you mentioned the large diameter rubber seal. Did you find yours damaged? Did you re use your old one or buy a new one? I get mine from maddog clutches.
    Oh one more question, did you find any of your springs cracked or broken?
    Nice work by the way.
  15. John M
    John M Formula Junior
    Nov 18, 2004
    887
    Kentucky
    Mitchell:
    Thank you for taking the time to write up this procedure!
    Best Regards,
    John M
  16. yelcab
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    Badabing, I will show the install when it goes in. There are plenty of posts on triple seals so I might not repeat it.
    Jack and Jill, I did change the large o-ring and forgot to mention it. The old one was not damaged. In fact, the flywheel grease did not leak at all. It was just good practice to change it at a clutch job. Pressure plate spring was all OK.
  17. yelcab
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    If anybody is wondering, the eight M8 ribe flywheel bots are torqued to 35 Nm, with blue Loctite.
  18. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
  19. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Another great thread. Thanks for sharing the info Mitchell.
  20. Badabing!
    Mar 30, 2014
    731
    NYC
    Maybe someone could post a link to the best thread on the triple seals in this thread so we can have all the pertinent info in the same spot.
  21. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Nice writeup!
  22. emac
    emac Formula Junior
    851
    upstate SC
    ernest
  23. Badabing!
    Mar 30, 2014
    731
    NYC
