How to fix a 308 door lock? | FerrariChat
Discussion in '308/328' started by Bloated Monkey, Mar 29, 2009.
  1. Bloated Monkey
    Jan 3, 2009
    11
    Houston, TX
    Tim
    #1 Bloated Monkey, Mar 29, 2009
    I have a couple simple questions about door locks. Miy '81 308 came without keys, so I was going to have the locks rekeyed. I pulled apart the door, and found that the lock was not connected to anything. I think I can see how it connects, but:
    1. Does anyone have a picture of how the door lock is connected from the inside? If I just connect the metal hook to the plastic thingy will I be able to work it manually, or do I have to get the electronics working?
    2. Is there another car that has the same lock mechanism that I might be able to find a replacement for, or is rekeying my best option?
    Thanks for the help.
  2. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    #2 ME308, Mar 30, 2009
    yes, connect the metal hook to the upper plastic part as you can see in my pic below...but you will need a key to work it ;)
    (electronics do not have to work to operate the lock manually)
    btw:
    as you can see in the picture, I worked around a little problem...
    usually at the end of the lock cylinder there is a small kind of ball joint which is pressed into a hole of the long plastic part and rotates a little when you turn the key
    since this ball joint is broken off/lost and the plasic part seems worn, I used a small screw and a hex nut to renew this connection -
    but it`s not a final solution because it doesn`t stay this way very long...before it pops out again...
    so I can only lock the door from the inside by pushing down the door nob
    not a real problem - just a little inconvenient since I usually open the door for passengers from the outside ... you know, old school ;)
    any ideas to fix it and sources for parts ?
    or directly to Bloated Monkey`s second question:
  3. Bloated Monkey
    Jan 3, 2009
    11
    Houston, TX
    Tim
    So I finally found someone to make a key for me - had to call 5 locksmiths before someone would touch a Ferrari lock.... Anyway, I installed it, and I'm having a time trying to get it to work. When the the little dohicky in the back of the lock barrel is not connected to the white circle, it hangs at 6 o'clock (see first picture above). It drives the lock down ok, and rotates all the way to around 5 o'clock but doesn't have enough travel to drive it up (only makes it to 7 o'clock). It seems to me, that the dohicky should instead be centered at 9 o'clock so that it would travel up the same distance as down. What am I missing?
  4. ferrari#7
    ferrari#7 Formula Junior
    Sep 8, 2008
    328
    Anyone experience the same problem as Bloated Monkey did above: concerning key will lock passengers door, but will not unlock it. The reason is because the mechanism in back of lock cylinder is connected to white plastic which hangs at 6 o'clock position. The key will only rotate this mechanism to 7 o'cloock position, which is not enough to unlock door. The exact same problem as Bloated Monkey above. Any suggestions.
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #5 Crowndog, Aug 30, 2011
    I am going thru the exact same problem. Do yourself a big favor. Call and talk to Brian at Ferrparts. Tell him you need the little gray plastic part that holds the L -shaped rod with threads at one end. That piece holds that metal L-shaped part that is upside down in your picture to the upper left hand piece in your picture. The yellowish part hanging is upside down. Simply rotate it up and you will see that it goes into the hole at the top. But you need the keeper-hence the call. I am assuming that the one that is in the picture cracked and that is why the rod is now dangling.
    Ferrar#7: I belive that rectangular piece that your piece plugs onto may not be long enough. The original plastic part which is threaded I think is adjustable in length (hence the threads) and you will find that the small rotation of the key is enough. IMHO Also, make sure that the plastic door lock button is not screwed down to far on the rod or it can't go down into the door far enough. (plastic piece with phyllips slot on top).
  6. ferrari#7
    Sep 8, 2008
    328
    Thanks Crowndog! I have the gray plastic part that holds the L shape rod. In the first picture above I believe the gray plastic part should be rotated to the left, and than L rod fits through from the left. Let me try that!!
  7. mwr4440
    57,931
    Bavaria, The 'Other' Germany
    Mark W.R.
    What do you guys do to keep the lock from rotating in the hole?
    I cannot get the large nut tight enough to keep the lock in place for more than 2 or 3 lock-unlock cycles with the key. :(
  8. BigTex
    79,368
    Houston, Texas
    Bubba
    It sounds like your fiber washer is missing, (see picture above) or you need to add a second one?
    More fiber!!!
  9. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    While you are in there, buy and install a Keyless Door Interlock. No more reaching across for the passenger side. Plenty to choose from on eBay...Google 'Rec-11' to see the one I installed, it's a reliable standard that's been around for quite a while.
  10. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    +1
    On my car, the keyed locks were very difficult to adjust. The strange angle of the lock/unlock lever coupled with the rod and lock cylinder make it a challenge. In the end, I was only able to get my driver's side to work -- I left the passenger's side unhooked. I have a Spal power door lock kit and a Viper keyless entry to lock/unlock. The driver's side key lock is now a "just in case" if the power locks fail.
  11. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    It seems that the REC-11 system has been discontinued. That means it most likely works too well and lasts too long. But I like the idea and there must be other similar systems. I will look into it. Great idea. Thanks
  12. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    When I had my 308 the passenger lock wasn't keyed the same as the driver's side lock for some reason. I took apart the passenger-side tumbler, played around with the little pins, and found a combo that worked with my key. It was pretty easy to do, but I probably got lucky inasmuch as the passenger-side lock contained the pins that I needed, they just needed to be re-sequenced if you know what I mean.
    Not sure that this has any relevance to the current thread, but thought I'd share my experiences anyway.
  13. mwr4440
    57,931
    Mark W.R.
    Thanx Tex. Will felt work or do I contact one of the usual suspects?
  14. LUKN4UBL
    LUKN4UBL Rookie
    Feb 15, 2007
    40
    Slightly off topic, but I used the search function and can't find a parts cross reference or a source for an '83 308 QV door key blank. Any suggestions?
  15. LUKN4UBL
    LUKN4UBL Rookie
    Feb 15, 2007
    40
    OK, did some more research on the door key and think I found a list of parts cross references. Maybe someone could confirm:
    Curtis FT-33
    Dominion SF3
    ESP F91CR
    Ilco F91CR
    JMA AF-5I
    Silca AF4C
    Taylor F72W
  16. westyguy
    westyguy Formula Junior
    Apr 27, 2009
    252
    Huntsville, TX
    Steve
    Here's a more comprehensive list of replacement blanks:
    728 Börkey AR7 Silca AR3 Silca AN6 Orion AS6 Orion AF9 Kis AB6 Orion SF6 Errebi SF3 Dominion SF3 HD SF8 Dominion SF8 Ilco SF8 HD SE3 RR FA6 Orion F10 Kis BG5 RR TA1 CEA IT14 Cole Nat'l AUB1 Silca AF4C Silca AF 5I JMA CRM1 CEA SAF4 CEA SAF2 CEA SF6A Errebi SF15 Lotus SF19 Lotus SF27 Lotus SF23 Lotus SE20 RR K133 Fuki FRA3 Lotus FRA8 RR F72W Taylor FAR6 Orion FAR6 Errebi FAR2 Silca FT 33 Curtis FT33 Hillman 1042 Börkey 124 6 Errebi TMA4 RR PG18 Kis CRA16 RR F91CR Ilco FAR 1I JMA FARM1 CEA
    Steve Sandlin,
    Registered Locksmith
  17. ThreeSixtyM
    ThreeSixtyM Karting
    Aug 3, 2009
    111
    Apologies for the tread resurrection, but I’m having a problem with my door lock and a search brought up this thread.
    Looking at the first photograph posted; the disc with the little ball joint has come adrift from the end of the lock barrel on my passenger door, when the key is turned the disc now doesn’t turn to activate the lock/unlock mechanism.
    I can’t see how this disc is fixed to the lock, there are holes drilled through the internal shaft of the disc and also the barrel itself, but using an improvised split pin doesn’t work.
    I’d be very grateful for any help. I’ll take a look at the other door lock, but am wary of causing any damage to that through inspection and disassembly
    All replies greatly appreciated.
